Latest post 08-27-2007 10:24 PM by saogiova. 8 replies.
Page 1 of 1 (9 items)
  • 08-09-2007 7:19 PM
    Grand Prix Moderne 609 K repair
    Hello at all,
    I'm writing from Venice - Italy.
    I acquired some days ago in Denmark a wonderful Grand Prix Moderne 609 K.
    I wait for nearly 2 years in order to find it.
    Now I'm repairing the final stage of the left channel that does not work.
    I need a little aid.
    The posterior panel lacks me. Someone can send an image to me made with scanner therefore I can construct another equal?
    Someone can sell to me the plug that goes inserted income of the Turnable inputr? Evidenced in yellow in the photo.
    Someone can sell the handbook/owner manual to me in English?
    Thanks for the aid.
    Giovanni Saoner
    My website:   http;//www.casaparadiso.it
    My family:     http://www.casaparadiso.it/noprofit.htm
    My email:      info@casaparadiso.it
    Filed under:
  • 08-10-2007 4:23 PM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Re: Grand Prix Moderne 609 K repair
    Sounds like a thing Frede Kristensen would be the man to ask about !
    Lee
  • 08-10-2007 6:45 PM In reply to
    Hello Lee,
    thank you very much for your information.
    Because I'm a newbie of the forum, what I must make to contact Frede? Have you his email address or his Beoworld nickname ?
    If I upgrade my account I will find the Grand Prix Moderne 609K owner manual on the User & Service Manuals section?
    Giovanni
  • 08-10-2007 7:05 PM In reply to
    • 9 LEE
    • Moderator - UK
    • Posts 5,223
    Hi
    We don't have either - but i will email Frede and make him aware of your thread. Hopefully he can help!
    Lee
    Big Smile
  • 08-11-2007 4:49 AM In reply to
    I would imagine that Martin can also help (Dillen).
  • 08-12-2007 8:55 AM In reply to
    Thank you very much Peter, I'll try to contact Dillen. Your information was very useful.
  • 08-12-2007 10:09 AM In reply to
    • Dillen
    • Copenhagen / Denmark
    • Posts 5,008
    Nice radio !
    I never saw any english language user manual for this one and I don't even have the danish one.
    I have a couple of backsides from scrapped sets but none for this model.
    I am pretty sure that I have this model in my collection though but it may
    be out of easy reach, packed in a storage box among hundreds of other boxes.
    I will try to find it and see if I can take a photo of the backside.
    The 3-pin plug for the turntable will be a bit hard to find.
    I take it that you are looking for the plug that goes on the turntable signal cable and not the one mounted on the radio chassis (which I may be able to locate).
    I have a B&O turntable for sale though with the correct plug mounted.
    The deck is the type 608VF (with the old counterweight and built-in RIAA preamp). Interested, drop me a PM.
    While you are in there, do yourself and the radio a favour and
    replace the 6 blue axial electrolytic capacitors located at
    the output stage board (the vertical board holding the 4
    output valves which seemed to be missing when the photo was taken).
    Mounted just above the output valves, these caps are in a fairly
    stressed location, I recommend you fit 105deg components.
    This is the Grand Prix Moderne 608.
    Not exactly the same as your 609 (different plug locations etc) but the style is correct :
  • 08-12-2007 6:06 PM In reply to
    Thank you for yours very important and precise indications.
    This unit is very beautiful (at least for me that I have tried it for years)
    The only defect is that it does not have a FM Stereo Decoder.
    I have repaired the final stage (the hoof of the first ECL86 had been crushed) and now all works perfectly.
    The polarization voltages are corrected but I will replace however the capacitors, you given a good suggestion to me.
    I connected the DVD player to ithe DIN plug for the Beocord (on the pin without 2,2 Mohm resistors).
    Now I understand because the level of the volume remains low if I listen a CD, the 608VF was preamplified, while the exit of the DVD Player is only 200 mV.
    Now I rebuild the backside.
    If someone need diagram or photo for this machine I will be happy for being useful.
  • 08-27-2007 10:24 PM In reply to
    Hello Dillen, have you received my email?
    I'm interested to buy the  608VF for the cable and the 3-pin cable.
    Can you tell me the price?
    Giovanni Big Smile
