Latest post 08-13-2007 4:06 PM by Max. 8 replies.
Page 1 of 1 (9 items)
  • 08-09-2007 6:19 AM
    BS3000 - is it possible to upgrade it to DAB
    Hi All
     I was wondering if it was possible to upgrade the Tuner part in my BS3000 to Digital Radio rather than analogue? and if so how much it would cost?
     regards
     Andrew
    Beovision Avant 32 RF, DVD1, Beovision 1, MX4002, Beound 3000, Beolab Penta MKII, Beovox Penta, Beolit 707, Beolink Passive, Beovox C30, Beocom 4, Beogram TX, 4 x Beo4, Form 1 & 2, Beocenter 7700, Beovox S65,
  • 08-09-2007 6:39 AM In reply to
    Re: BS3000 - is it possible to upgrade it to DAB
    Not possible I'm afraid. What you can do is plug a portable DAB radio into the AUX port and listen through the 3000 and speakers.
    Regards Graham
  • 08-09-2007 7:25 AM In reply to
    Or something like this will do the job http://www.inest.co.uk/products/DA-1_DAB_Receiver_-_Remote.asp there are a few diferent types on the market, I would imagine quality will vary slightly.
  • 08-09-2007 8:00 AM In reply to
    There is.....
    BS4 or BC2
    sorry, couldn't resist! Devil
  • 08-09-2007 8:47 AM In reply to
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    If you can, hunt down a DAB beocentre 2300???? Then you could swap the clamper, so it looks like a one of a kind BS3000! Big Smile Gee you'd have to be lucky to find one though hey
  • 08-09-2007 9:07 AM In reply to
    • ChrDH
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Denmark
    • Posts 493
    Best Buy in Denmark (bbuy.dk) got a beocenter 2300 DAB version for sale (about £700 I think), they had it last time I was in their physical shop (2 weeks ago), but it is rare, only 500 of them produced. I was actually tempted but got a 2hand ouverture instead.
    best regards
    Chr.
    Beosound Ouverture, Beocenter 9000, Beovision MX6000, Beocord VX7000
  • 08-09-2007 10:29 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    http://www.radioogtveksperten.dk/shop/shop/handel/info.asp?vare=246
    Around 250 Euro, can be used with Beo4/BL1000.
    Best regards
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 08-13-2007 7:24 AM In reply to
    Thanks for the replies, I'm going to look at installing a proper outside aerial - seems the cheapest option.
    Thanks again
     Andrew
  • 08-13-2007 4:06 PM In reply to
    • Max
    • Not Ranked
    • Devon
    • Posts 64
    Its makes a big difference, I installed one in the loft a friend of mine thought the source was DAB when listening to my BS3200 via a BL3500 in the kitchen. Unless you need the additional stations the analogue tuner does a good job at presenting a clean and crisp signal.
    Max.
    My B&O is in my Bio.
