Latest post 08-10-2007 11:30 AM by soundproof. 27 replies.
Page 2 of 2 (28 items) < Previous 1 2
  • 08-10-2007 3:06 AM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: The power of BeoLab 3
    David:
    Maybe it's the ABR's being free that makes it possible to sounds so awesome outdoors, and keep a coherent level of bass. The sound muddles when you turn them up in a confined space.
    That goes for almost all speakers other than BeoLab 5s. However, I'm impressed that 3s managed to sustain a decent amount of bass outdoors.
     Weekly top artists:
  • 08-10-2007 5:53 AM In reply to
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    Well, as i said, it may be the ABR's! Big Smile The BL3's more so than most other speakers, muddle when turned up in domestic situations.
  • 08-10-2007 11:30 AM In reply to
    Alex:
    David:
    Of course, you can't be yards and yards away from them. The energy dissipates quickly when there are no walls. On the other hand, absolutely no risk of artificial boominess. For my preferred use, it's perfect to be outside, as you can really dive into the music when there are no primary/secondary/tertiary reflections to take the edge of the direct signal - and the bass is there. (These are quite special, in that they have the soft-rubber vents working away and shifting air).
    All in all, a very pleasant experience.
