Somehow the MX3500 looses its setting for the motorstand ? or fails to send it turning signal ?
When first conected the motorstand didnt work after advice from a dealer I grasped that the mx3500 needs to be callibrated when a new device is added. so unplug and after a period of time reconect and it will `read ` the new devices and sets it output for it.
So i did it and voila it worked. But after a while the picture>stand procedure wouldnt work anymore ?
I figured it had to do something with the new setting not being saved ? for longer period or that if it isnt saved it will reset to no motorstand signal ? ( if you know how it exactly works feel free )
Somehow it worked for a period of time fine after i did the following unplug>connect>picture-stand >turn into preset position and store .
I recently added a VX5500 same procedure as above. But now it wont keep the turning ability. After a while it will not turn anymore. When turned of by link 1000 it will take the returning time before giving turn off flash but wont turn
Basic questions :
* does it all need to be stored ?
* does menu has anything to do with it
regards
