Latest post 08-08-2007 2:19 PM by The Stig - ver. 1.7. 5 replies.
Page 1 of 1 (6 items)
  • 08-06-2007 9:14 PM
    Beocenter 2 not responding
    I have a Beocenter 2, early version, hooked to 2 Beolab 6000s, a Beovision 3 and 2x Beolab 2000s. Oh and  PC2 (on a mac). So far so good. After a power cut (we were away) I came back to find that the Beocenter 2 only recognised commands from the Beo4 for TV, Sat and DVD, but not radio, CD or N Music.
    I have tried to reset the options manually, checked the cables, and to be honest, I'm completely stumped. If it was dead, I'd understand, but I can get the thing to play CDs (and the radio) in other rooms on the Beolab 2000s... but not in the main room connected to the telly.
    Any ideas gratefully received.
    Ta
    Shan
  • 08-07-2007 12:41 AM In reply to
    • cozza
    • Top 500 Contributor
    • Joined on 04-18-2007
    • New Zealand
    • Posts 119
    Re: Beocenter 2 not responding
    Have you tried another remote? Sometimes the keypad contacts fail and a whole row or column of keys ceases to function.
  • 08-07-2007 5:23 AM In reply to
    Thanks Cozza
    I don't think that's it. The remote is registering the changes, with the display showing "RADIO" and "CD" when those buttons are pressed. Also, when I press Radio on the BeoCenter, it still doesn't work.
    CDs load and start playing when inserted without the help of the remote, but there is no sound. I'm left with thinking it could be a cable fault?
    S
  • 08-07-2007 5:43 AM In reply to
    Sounds like a masterlink glitch. Try a hard reset. Everything off at the mains for 5 minutes and then switch back on.
  • 08-08-2007 3:29 AM In reply to
    Thanks Peter.
    That didn't work by itself... but I have got most of it workng now by changing the configuration slightly... Used to have the speakers into the TV, rather than the Beocenter socket unit, and have now switched. Undid all the cables, and reinforced the option settings on V-OPT and A-OPT.
    Just got to get the N-Music link working now...
    Thanks for the help
    S
  • 08-08-2007 2:19 PM In reply to
    if it's a BV3-32" you have then also remember to set front speaker to none
