Latest post 01-06-2012 12:46 PM by valve1. 6 replies.
Page 1 of 1 (7 items)
  • 08-04-2007 6:46 AM
    • Beolab1
    • Top 500 Contributor
    • Joined on 08-04-2007
    • Hong Kong
    • Posts 232
    • Gold Member
    Connecting Beogram 9000 to BeoSound 9000 and keeping Datalink?
    Dear people at Beoworld,
    I bought a Beogram 9000 record player and connected it to my BeoSound 9000 with a new RIAA amplifier (German brand). It works perfectly and it even though the record player is 18 years old, it still sounds great. Having great fun listening to all the old records from the basement.
    It would be even better if I could control the record player with the Beo4 remote, but the new RIAA amplifier that I have now, does not support Data Link. I believe this will only work if I use a original Bang & Olufsen RIAA amplifier that has a 7 pin DIN plug in and out. Am I right?And if so, what type of Bang & Olufsen RIAA amplifier do I need and where could I get it?
    If someone here could solve the mystery for me I would be very happy! Thanks a lot!
  • 08-04-2007 6:59 AM In reply to
    Re: Connecting Beogram 9000 to BeoSound 9000 and keeping Datalink?
    I am afraid that the BS9000 does not support Datalink so no control of a Beogram by remote is possible. I believe Ridax may be able to offer a solution though. Try a PM to him.
    I don't think you will find a B&O RIAA easily either - it would be much easier to add a wire for Datalink - if that were the answer.
  • 08-04-2007 1:22 PM In reply to
    • Beolab1
    • Hong Kong
    • Posts 232
    • Gold Member
    Thanks Peter, hope that others can help me further.
  • 08-05-2007 5:51 PM In reply to
    • ridax
    • Not Ranked
    • Joined on 04-16-2007
    • Posts 44
    Yes, you could remote control the Beogram with my little device at http://home.swipnet.se/ridax/beoir.htm .
  • 01-06-2012 10:54 AM In reply to
    Hi guy
    Need some help, I have a Beosound 9000 Mark 3 with a pair of 8000's. I wish to place the 9000 on the wall so have to change the setting's with some kind of plastic key? Dose any one know where I can find one? I am a keen eBay'er so would prefer not to pay a fortune through a dealer!
    James
  • 01-06-2012 11:45 AM In reply to
    .....er! Why not tryIck! a screwdriver?
    Regards Graham
  • 01-06-2012 12:46 PM In reply to
    • valve1
    • Joined on 05-27-2009
    • Dublin Ireland
    • Posts 213
    • Gold Member
    joeyboygolf:
    ......or a coin, I am sure I did!
