1st March February 2012
Latest post 01-11-2009 1:58 PM by Alex. 21 replies.
08-04-2007 6:42 AM
steveh
- Joined on 08-04-2007
- Posts 2
playing my playstation on my B&O
hi guys i have been trying to hook my friends playstation 3 into a beovision mx7000, bear in mind that this tv is completely new to me
firstly i plugged the scart cable into the back and then fiddled around with the only two buttons that are visible(tv didnt come with controller) one says step and changes the channel and the other turns the unit on... after failing to locate an av button and failing to make the tv recognise the playstation automatically i plugged my dvdplayer in - immediately the tv recognised the dvd player do i need to try something different?is there an av button hidden away somewhere or do i need to buy a brand new controller or something? is this normal that there are only the 2 buttons... how do i fiddle with the volume without a remote? does a universal remote work with this model?
help would really be appreciated
Calvin
- Joined on 04-16-2007
- London
- Posts 233
Re: playing my playstation on my B&O
I don't know the model but you could try holding the step button and seeing if that switches mode to AV? You probably need to use a remote though. Of course, if you can't justify paying a lot of money just to occasionally plug in someone else's playstation, you could indeed get one of those cheap universal remotes - they do seem to work with B&O equipment, even if they generally look horrific
mobeyone
- Joined on 03-27-2007
- UK
- Posts 955
If you go into menu>setup>sockets> and then select a different source on the scart you are using, this should do it.
*edit* Just read you do not have a remote.. I will check mine to see if you can do this without the remote, doubt it to be honest.
joeyboygolf
- Ely, Cambridgeshire, UK
- Posts 3,252
You are snookered without a remote I'm afraid. You need to set up the scart to expect a VCR. Then plug in the playstation and select VTAPE on the remote and bingo, it works! Unfortunately you can't do any of this without a remote. If you don't have a B&O remote I can recommend the RUWIDO rIR9843 as a very cheap alternative.
Calvin
- London
- Posts 233
Actually, If you're going to tinker with technical setups, could you not just get a converter so you can plug the playstation in like a TV ariel?
steveh
- Posts 2
okay guys thanks a lot for your help i bought the universal
remote and cracked it open and was delighted to see it function when
channel changing, and then i tried pressing the av button..... Nothing
happened! Very frustrating. in reply to the post above me-
the old playstation used to come with a wire that pluggedinto the
aerial and the scart on the ps3 is the same as the old playstation...
do you reckon if i use this aerial wire it might work? i'll give it a
try- i had best get searching for the bloody wire!
Christian
- Copenhagen, Denmark
- Posts 626
The AV button is not the right one, it is when you want a video divice to control a music system or vice versa. You can press AV and then CD when you want your tv to control a CD player, but I assume the Beovison is a sand alone unit, so this does not apply to you. To active the SCART you must press V.Tape, and be sure that it is activated in the menu. To acces the menu, just press menu, and follow the on screen instructions. Christian
Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
Addicted? Oh no.... ;)
Alex
- Bath & Cardiff, UK
- Posts 2,990
Universal Remotes don't support all the B&O commands, in fact they only actually support the absolute basics (for some reason). I guess it's because most comanies simply use a button to cycle between different inputs. B&O are not the same, and treat inputs completely differently. If you press 'SAT', then it'll go to a whatever scart connection you've told it the satellite box is connected to in the menu. Difficult to set up, but when it comes to actually using the TV, it makes life much easier.
You'll need a Beo4 remote or a BeoLink 1000!
Weekly top artists:
joeyboygolf
- Posts 3,252
The plastic remote that I have suggested above replicates all the keys on a BL1000 and costs less than £10 Using MENU and SETUP on the MX assign AV2 to VTAPE Plug the scart from the PS3 into AV2 on the MX then press VTAPE on the remote and you should have PS on screen.
Alex
- Posts 2,990
Oh stop being so helpful you!
Weekly top artists:
The Stig - ver. 1.7
- Joined on 06-20-2007
- Posts 898
joeyboygolf: The plastic remote that I have suggested above replicates all the keys on a BL1000 and costs less than £10
Yes! and you have to aim at the TV, like on all the good kingo's (or what it is you call the "no name" TV's) out there it's Shift+V-TAPE when using AV2 (it only possible to name it V.Tape2)
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
The Stig - ver. 1.2: joeyboygolf: The plastic remote that I have suggested above replicates all the keys on a BL1000 and costs less than £10
Kikinoko.
Jandyt
- Posts 13,004
Steveh. If you are still struggling, I will happily loan you a Beolink1000. Andy T.
The Stig - ver. 1.7
- Posts 898
haw did thy come up with this name?
Jandyt
- Posts 13,004
I think Ed started it. When we were beta-testing the new Beoworld in the gap while the old site was down and the new one hadn't gone on line, Lee, Ed and myself used the word Kikinoko as a standing joke and it just well....er..stuck! Andy T.
joeyboygolf
- Posts 3,252
jandyt: The Stig - ver. 1.2: joeyboygolf: The plastic remote that I have suggested above replicates all the keys on a BL1000 and costs less than £10
Kikinoko. Quite correct.......
EDIT!! My MX is at my daughter's house at the moment so I can't check but eldest grandson assures me that he is plugged into AV2 and only needs to press VTAPE to get his PS on screen.
The Stig - ver. 1.7
- Posts 898
It maybe depends on the SW then, does I've seen it only possible to name AV2 V.TAPE2. No matter what AV1 is set to...
Adrian02
- Joined on 01-11-2009
- Posts 2
Hi, I have the same problem but I can only get the sound. The picture is missing. Equippment: Beovision MX 7000 Beolink 1000 Playstation 2 Thanks and regards, Terje
Dave
- Joined on 04-17-2007
- Brisbane, Australia
- Posts 2,328
hmmmm tried jiggling the plugs? I sometimes have to re-fasten one of my rubbish scart cables... or maybe try plugging into another input of the mx... obviously selecting accordingly in the menu of the tv
Adrian02
- Posts 2
Do you use Beo4 or Beolink 1000 as remote controll?
Alex
- Posts 2,990
What colour are the plugs which are going into your MX 7000 from the PS3?
Weekly top artists:
Page 1 of 1 (22 items)
