Latest post 09-03-2009 9:46 PM by Klas. 15 replies.
Page 1 of 1 (16 items)
  • 08-03-2007 8:22 PM
    • Goldfrog88
    • Top 500 Contributor
    • Joined on 06-07-2007
    • Melbourne, Australia
    • Posts 83
    • Gold Member
    BS3 software upgrade. Is it difficult?
    Our Service Centre in Melbourne say that a software update from 2.7 to 3.1 for the BS3 would not make an Apple TV remote controllable unless specifically added into the list during the upgrade. Is upgrading the software difficult? Does 'the list' not get transferred for selection and appear like that of the STB listing? I'm trying to make the process as simple and cost effective as possible, and don't really want to unplug all the cables and lose the BS3 for two or three days (every time to upgrade) ...
  • 08-03-2007 9:30 PM In reply to
    Re: BS3 software upgrade. Is it difficult?
    Our Service Centre in Melbourne say that a software update from 2.7 to 3.1 for the BS3 would not make an Apple TV remote controllable...
    yes thats true, but when they already has the BS3 plugged to a PC it only takes a minute to update the puc (stb) also... I don't know any thing about the appel tv, some people in here says it can be controlled so I think it can...
  • 08-04-2007 1:51 AM In reply to
    • Roger
    • Top 75 Contributor
    • Joined on 03-28-2007
    • Norway
    • Posts 870
    It is easy as long as you follow the on-screen instructions on the laptop (plug in/out, power up/down when the computer tells you to - do not add common sense, then you will have to start all over if you are lucky - which is the reason why dealers do not let you take their service computer home). But it would be pretty straight forward for an average BeoWorlder... it is so much easier than unplugging and returning a product to the dealer.
    Roger
  • 08-04-2007 7:41 AM In reply to
    • Goldfrog88
    • Posts 83
    • Gold Member
    Many thanks for your prompt replies guys. Its nice to know there's help from people who really do know. Cheers!
  • 01-04-2008 5:13 AM In reply to
    • Klas
    • Joined on 04-19-2007
    • Singapore
    • Posts 96
    do we still have to hand it in to a service shop to get the SW upgraded or someone been able to get hold of software and patches so It can be done ourselves?....its a lot of hassle to get them updated each time....
    Cheers
    Klas
    Grant me the serenity to accept the B&O I can't afford
  • 01-04-2008 5:21 AM In reply to
    • moxxey
    • Top 25 Contributor
    • Joined on 04-14-2007
    • South West, UK
    • Posts 2,360
    I would have thought that the dealer will perform this upgrade for you, as it only takes a small amount of time (when my BV7-32 was HD upgraded, they had to perform a SW update, which took less than 20 minutes, if I can remember). You could either pay your dealer to visit you or, if you ask nicely, they may send someone round at their convenience.
    I'm wondering what is updated in the BS3 4.0 SW update? Anyone know?
  • 01-04-2008 5:47 AM In reply to
    • Klas
    • Singapore
    • Posts 96
    thanks Moxxey - i'll give them a call and see if they are feeling nice this year....my unit got shipped from fabric two days before 4.0 got released so i'm keen on getting the new one and trying it out
  • 01-04-2008 8:16 AM In reply to
    Klas:
    is 4.0 confirmed?
  • 01-04-2008 7:29 PM In reply to
    • Klas
    • Singapore
    • Posts 96
    ohh....my source was this forum - seperate thread - where someone mentioned 4.0; I don't have a 2nd source but i'll inquire next week when the service store opens their ports
  • 01-05-2008 6:39 AM In reply to
    • Gerd
    • Top 150 Contributor
    • Joined on 04-20-2007
    • Germany
    • Posts 523
    ....mr anders(son):
    is 4.0 confirmed?
    It is! New features are
    - Support for BeoLab 10
    - Support for Samsung A800 (FDH, EU)
    - Support for Sim2 HT-3000 (FDH, US)
    Timer recording (menu and execution changed)
    First time press on MENU goes to the active source, not the TV menu
    Large function implemented in teletext
    Possible to select 'DVD2' as DVD source in the CONNECTION menu
    + several software corrections ...
  • 01-05-2008 6:50 AM In reply to
    Gerd:
    ....mr anders(son):
    is 4.0 confirmed?
    Great!!!
  • 01-05-2008 3:13 PM In reply to
    • Mico
    • Joined on 05-06-2007
    • Finland
    • Posts 136
    Anything about 24p?
  • 01-06-2008 6:26 AM In reply to
    • Gerd
    • Germany
    • Posts 523
    No - nothing
  • 01-07-2008 11:22 AM In reply to
    Gerd:
    ....mr anders(son):
    is 4.0 confirmed?
    I have updated my BV9 now with sw 4.0
    And can confirmed some of above
  • 03-10-2008 11:11 AM In reply to
    To Gerd! Do you know if BV7-40 MarkIII or BS3 support 24 fprs now with sw 4.12?
    Regards Martin
    Beolab 5 with sw 3.0,  BV7-55 3D without Bluray(MK II), Beolab 7-4, Beolab 4000 MKII, Beolab 3500, Beovox CX100, Beosound 9000 mkIII, Cabinett 2054, Beo4 MKII, Oppo BDP-93 Blurayplayer (B&O-version)
  • 09-03-2009 9:46 PM In reply to
    • Klas
    • Singapore
    • Posts 96
    anyone know what the latest SW version for BS 3 is?
    Anyone know what next major version is being worked on; what it will contain and ETA?
    Havent upgraded my unit for 2yrs and its time to get the B&O folks out.....
