1st March February 2012
Latest post 08-06-2007 1:22 AM by Dave. 16 replies.
08-03-2007 2:49 PM
ngupta24
- Joined on 08-03-2007
- Posts 8
beosound 4 aux connection
Hi, I have a pair of beolab 1s and a beosound 4. I would like to connect my non-B&O tv, an iPod and maybe a non-B&O dvd player as well... I dont know how to go about this since there is only one AUX input on the beosound 4. Please help me with the same... Cheers Nick
Christian
- Joined on 04-16-2007
- Copenhagen, Denmark
- Posts 626
Re: beosound 4 aux connection
Welcome to BeoWorld!  If the DVD is connected to your TV, as I suspect it is , it should not be nessesary to connect it to the BeoSound also. This should reduce the number to two, the TV and your iPod. For this you should use an AUX splitter. Since you are connecting non-Beo equipment, you can use any mark of cable, as long as all five wires are connected. So you will need a 5 DIN Y-splitter and some 5 DIN cables. If you have any doubt, please ask again. Regards, Christian
Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
Addicted? Oh no.... ;)
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
Think the Beosound 4 has RCA connections. So DIN splitters are of no use, I was going to suggest a CD/TAPE adaptor. Did not because of this. Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
Kokane81
- Joined on 06-17-2007
- Posts 63
Beosound 4 has rca/ phono for aux connection.
TheMajor
- Joined on 05-10-2007
- Tokyo
- Posts 251
I have a beosound one and its connected using a connector as stated above. Its easy to do just ask in the B&O store.
Beosystem 7000/6500- Beolab 4000 - Beosound 1 - A8 - Earset 3 - Beo4
ngupta24
- Posts 8
thanks for the quick reply guys... since i need to connect a computer as well (dont want to go through the tv) and hence need 3 connections to the beosound 4, what would you guys suggest?? still go with an aux splitter / switcher ? also will this affect sound quality and any good brands you could suggest ? Im living in the uk so would appreciate it if anyone has a web link to a good quality aux splitter / switcher i could buy... Thanks again Nick
meandmyshadow
- Joined on 04-17-2007
- Posts 339
Buy yourself a decent audio switcher (QED make a very good one), then get appropriate cables from someone like flashbacksales.co.uk, you will not have any real issues with sound quality and most importantly, enjoy  .
Christian
- Posts 626
I assumed that BS4 was equipped with normal DIN AUX, but it seems I was wrong sorry  Christian
Alex
- Bath & Cardiff, UK
- Posts 2,990
First time B&O have done this since the BeoMaster 5000 on their audio systems.
Weekly top artists:
The Stig - ver. 1.7
- Joined on 06-20-2007
- Posts 898
Alex: First time B&O have done this since the BeoMaster 5000 on their audio systems.
No also on BC2... so think this is the way thy will go from now on..
Craig
- Posts 4,855
Logical since they dropped Datalink. Craig
ngupta24
- Posts 8
anyone know of an audio switcher that can be controlled by a remote??
ngupta24
- Posts 8
does anyone know of an audio switcher that can be controlled by a remote?? p.s. sorry for the double post, i dont know how to delete it...
Craig
- Posts 4,855
So all of the BS4's connections are under the base then. Never knew that. Craig
The Stig - ver. 1.7
- Posts 898
ngupta24:anyone know of an audio switcher that can be controlled by a remote??
Never seen one, But I haven't look for it eider. You can get a scart splitter thats remote controlled, you can use this...
Dave
- Brisbane, Australia
- Posts 2,328
I have a BS4 and my setup is identical to yours. I connect a long RCA cable that travels all the way to my TV unit. What my setup consists of is a TV, DTV box and DVD recorder. The DTV box is linked to the DVD via scart, and the DVD is then connected to a scart converting cable which goes to my TV (RCA in). The TV only recieves video from both sources. The audio plugs from the scart converting cable are connected to the RCA cable with a piggyback RCA plug to RCA plug adapter (from tandy's or whereever). The ipod was connected also to this piggy back adapter. There is then no need to switch the sources, it works PERFECT with no interference. The only thing to remember is not to have more than one audio source going to the BS4. It's safe, but the sound of the ipod mixed in with the TV. I don't have an ipod anymore so it's just the SCART sound (DTV box, DVD recorder) that goes to the BS4. This procedure cost me less than $20.
Page 1 of 1 (17 items)
