Latest post 11-25-2007 6:37 PM by griemer. 8 replies.
Page 1 of 1 (9 items)
  • 08-03-2007 1:35 AM
    remote control not working
    HI Guys, I finally found a used MCP 6500 for my Beomaster 6500, but when I try to use the MCP, it said no contact when I press any buttons. Does the MCP 6500 need to be programmed to link up with my Beomaster 6500? Thanks in advance.
    Frank
  • 08-03-2007 1:55 AM In reply to
    Re: remote control not working
    It may be that the BM6500 is set to option 0. Have you a Beolink 1000 as well?
  • 08-04-2007 12:04 AM In reply to
    yes, I have a BEolink 1000 too, but it doesn't seems to work either. How do I set the option to 1 again?
    Frank
  • 08-04-2007 2:13 AM In reply to
    Set the system to standby then
    With your Beolink 1000
    SOUND 1 STORE
    The standby light on the system should blink if the command is received and your remotes should now work.
    Regards Graham
  • 08-06-2007 10:59 PM In reply to
    Still nothing, I wonder if the Beomaster 6500 is not receiving. any other possibilities? thanks.
    Frank
  • 08-08-2007 2:25 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Is your beolink 1000 definately working OK?
    If you know it is, then try pressing the AV button once then retry as above.
    Chris.
  • 09-20-2007 12:42 PM In reply to
    finally found someone with a Beomaster 5500 to try the remotes, the remotes are working, it is my Beomaster 6500 that is not receiving.
    Thanks for all  the help though
    Frank
  • 09-20-2007 2:40 PM In reply to
    • Jandyt
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Frank, it could still be an option problem. Try what Chris said about the AV button.
    Oh, and make sure you are within range of your Beomaster.
    Andy T.
    Poor me, never win owt!
  • 11-25-2007 6:37 PM In reply to
    Frank - I've got exactly the same problem. Did you find a fix? Grant
