Latest post 07-31-2007 10:21 AM by Alex. 6 replies.
Page 1 of 1 (7 items)
  • 07-31-2007 8:16 AM
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    Beoplayer!
    Hi i know this post should be in the general forum, but i really want to know an answer to this, as do all MAC owners! Will there ever be Beo software for mac? I really loved beoplayer when i had a pc, and it would just be fabulous if B&O were going to create a program for mac! Cheers for any replies, has anyone heard anything down the grapevine?
     David  Smile
  • 07-31-2007 8:25 AM In reply to
    Re: Beoplayer!
    Beoplayer is nothing but a "wrapper" or GUI that uses Windows Media Player - so no. There wont be a Mac version.
     You can use BMLink from here to control your BeoPort though: http://www.odlund.se/bmlink/
    ...also I dont see why one would want BeoPlayer - as it really isnt any good IMO.
  • 07-31-2007 8:44 AM In reply to
    • Dave
    • Posts 2,328
    Re: Beoplayer!
    That is your opinion, i found that beoplayer is REALLY nice to use. Very classy interface. iTunes, to me - is horrible. It's crude & sterile - like fluorescent lighting.
  • 07-31-2007 9:25 AM In reply to
    Re: Beoplayer!
    Must confess that when I changed from PC to Mac, moving across to iTunes from beoplayer was marvelous! Couldn't bear Beoplayer though I did like the B&O style design. BM-Link is superb - thanks Anders!
  • 07-31-2007 9:26 AM In reply to
    Re: Beoplayer!
    If you have an Intel Mac, you can run Beoplayer through Bootcamp though, can't you?
  • 07-31-2007 9:33 AM In reply to
    Re: Beoplayer!
  • 07-31-2007 10:21 AM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: Beoplayer!
    BeoPlayer doesn't work under CrossOver, but I imagine it'll run under Paralells fine.
     Weekly top artists:
