Latest post 02-12-2012 6:06 PM by Step1. 54 replies.
Page 3 of 3 (55 items) < Previous 1 2 3
  • 01-07-2008 6:31 AM In reply to
    • js
    • Top 500 Contributor
    • Joined on 09-07-2007
    • Brussels
    • Posts 208
    • Silver Member
    Re: Peter's Beolink 7000 ........Great fun!
    I just did the same as Colin, it works perfectly and cost me only a few pounds.
    Colin, thanks a lot for having shared your experience !
    Kind regards,
    Jean-Sebastien
  • 01-07-2008 6:36 AM In reply to
    • Colin
    • Not Ranked
    • Joined on 08-14-2007
    • Dorking, Surrey
    • Posts 35
    • Silver Member
    Great, Jean-Sebastien. Glad it worked for you too.
    I've certainly not experienced any problems at all with it to date.
  • 11-03-2008 6:37 AM In reply to
    Hi guys,
    I'm new here. Reading this thread has been very helpful for replacing my Beolink 7000 battery. Thank you for sharing all your hints and experience!! As I was looking for a battery replacement pack, I found this on ebay:
    http://cgi.ebay.de/EMPFANGERAKKU-MINI-SANYO-6V-1000mAh-NiMH-GRAUPNER_W0QQitemZ190263269201QQcmdZViewItem?hash=item190263269201&_trksid=p3286.c0.m14&_trkparms=72%3A1229%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
     Does any of you guys know if this is a pack I can use as a replecment pack?
    Thanks in advance for your replies!
    Beo_freak
  • 02-12-2012 2:35 PM In reply to
    Source for Beolink 7000 (BL7000) battery packs
    This is an old thread, however this information is still of use. I have had excellent success ordering from Cheap Battery Packs (cheapbatterypacks.com). You select a configuration step by step, and they build up a battery pack for you. The terminals are properly welded on with a solder tab if you specify "no wires" and "no plug". Here is an example part number: C-5-ELITE1700AA-Flat Pack-No Wire-No Plug. It cost about $22.
    A couple of tips - remove the lower cover, and pull off the round fuse while doing the soldering. The pack comes wrapped in a thick clear plastic - which is there to keep you from shorting the terminals (easy to do). However, the plastic keeps the batteries from properly nestling into the remote. So I remove the plastic, then immediately put electrical tape across the terminals. I always find the longest part is routing the wires after I'm done to make sure the cover will close properly.
  • 02-12-2012 6:06 PM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    Re: Source for Beolink 7000 (BL7000) battery packs
    I just want to say - I have recently repaired a couple of these and was shocked to see the batteries charge at a rate of near 300mA, for a good number of hours until a predetermined voltage is reached. The charge process is then pulsed every few seconds as if to determine cell voltage. I am not surprised that there are so many problems with replacement batteries! I would only use good quality branded stuff like the original Sanyo types!
    Olly.
