Datalink is the language used between components in a system - for instance a tape deck and receiver,
Master Control Link is the system used in mainly amplified systems to sent signal and data to link rooms. The signal is at an amplified level.
Audio Aux allows integration of video and audio products using a line level signal and datalink - it is two way.
Masterlink is the replacement system which has the signal at variable line level along with a different data signal - faster but easily translated compared to MCL.
Both MCL and ML carry signal two ways - to and from the main system.
Powerlink is the variable line level sent to active speakers - it appears in systems with either MCL or ML. It also carries data and switching signals. It is a one way system carrying signal from the product to a speaker.
Speakerlink is an amplified signal but also carrying data and switching signals - it can be regarded as the precursor of Powerlink.
Does that help?
