Latest post 07-30-2007 2:38 AM by Frank Rizzo. 4 replies.
Page 1 of 1 (5 items)
  • 07-28-2007 1:14 PM
    ML / MCL strange ....
    After looking at the MC / MCL converter and it's connections, i found and bought one on Ebay...  I intend on running a connection from a Beocenter 9500 (would that be Powerlink or Datalink??) to the MC / MCL....
    Then Connecting an IR (hockey puck) to the IR connection and connecting Passive speakers to it....
    Basically, using the MC / MCL converter as a Passive off the Beocenter 9500....
    Question is, 1) will this work? and 2) What connection do i make off the 9500??  The Powerlink 1 or 2 or AUX link??
    THanks, K
  • 07-28-2007 1:22 PM In reply to
    Re: ML / MCL strange ....
    OH...the strange thing to me...is in the Handbook for the MC / MCL...converter...it has a Powerlink connection over to an old style MCL eye......and box...
    Strange to me is why not just hook a new style IR round eye to the IR connection of the MC / MCL....just doesn't make sense...
  • 07-28-2007 6:36 PM In reply to
    Re: MC / MCL strange ....
    Hi Mecca
    The thing you look at in the handbook is the old MCL Link connection, where you have a box (1 or more) connected to the speaker out on the ML/mcl converter,and then to link rooms, up to 6 as i recall. Speaker and Ir eye is connected to the little box instead.
    If you connect the Ir eye directly to the converter it becomes a beolink passive instead and will only work in 1 link room with Passive speakers..
  • 07-28-2007 6:38 PM In reply to
    ahhhhh...thanks...got it.....
  • 07-30-2007 2:38 AM In reply to
    So practically.....I can take a Powerlink (say Powerlink 2) off the Beocenter 9500 and run it to the ML / MCL converter....and just use it as a passive, yes???  (with an IR eye).
    thanks...
