Actually, this is quite a common issue particularly on very dry days, not a lot of those lately in the UK.
The Beosound 9000 along with most other modern B&O equipment does not have a mains earth connection because the chassis and signal grounds are isolated. You can earth the stand without problems. If it is near a metal radiator pipe, that would be OK for a static discharge path.
