Latest post 07-30-2007 11:52 AM by beo4me. 3 replies.
Page 1 of 1 (4 items)
  • 07-26-2007 3:35 PM
    connecting a sacd (sony) to BV7
    I have been given a Sony SACD player, and thought that it must be possible to connecct it to the BV7.  Dealer didnt know, but a quick call to B&O technical and apparantly I can use the AV connections - does any one know how?
  • 07-26-2007 7:31 PM In reply to
    Re: connecting a sacd (sony) to BV7
    Everything I have read on SACD seemed to indicate that a direct connection was needed to the individual speakers and that connecting to a Beovision was not possible. If there is a way to do so I would very much like to know about. It was about a year ago or more that I researched it so maybe it has changed. We have an Avant and Beolab 9s and are considering a Beovision 7. I would really like to hear SACD through the 9s.
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 07-29-2007 4:46 PM In reply to
    Most SACDs provide two formats: DSD-Stereo and DSD-5.1 multi channel (many disks are so called "hybrid" disks that provide a standard CD layer also). On the other hand there are SACD players avaiable that support both stereo and 5.1 multi channel as well as many players that support bare stereo. Any SACD player can be connected to a B&O system however it will be restricted to stereo has the B&O systems do not provide analogue multi channel inputs. You just have to connect the stereo output of the SACD player to the AUX (or SCART) input of your B&O system.
    Hagen
  • 07-30-2007 11:52 AM In reply to
    Connecting the player via SCART might require a Cinch to SCART Adapter. That's the way I have connected my DVD-A player: LR-Cinch + FBAS -> Adapter -> SCART. I only have 2 channel, not surround, but the quality is top-notch when you have good cables and adapter.
    Frank
