Latest post 04-17-2007 5:25 PM by Dillen. 4 replies.
Page 1 of 1 (5 items)
  • 04-17-2007 12:34 PM
    • ChrDH
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Denmark
    • Posts 493
    Capacitor-kit for RL-speakers
    Hi there
    I remember on the old forum Dillen (Martin) once advertised his capacitor upgrade (refurbish) kit for the RL range of speakers. Apparently exchanging the old capacitors will improve the sound. As I have just moved and my RL6000 are not installed on the walls yet, I thought I might as well put some new capacitors and check the drives while they are not "in the air".
    BUT: Where is Dillen (Martin)? It would be too great a loss if he is not around any more...
    Best regards
     Chr
    Beosound Ouverture, Beocenter 9000, Beovision MX6000, Beocord VX7000
  • 04-17-2007 12:43 PM In reply to
    • Kevin
    • Top 50 Contributor
    • Joined on 02-15-2007
    • Moderator
    • Posts 1,256
    Re: Capacitor-kit for RL-speakers
    He is around ie. registered and I'm sure will pop up as I'm writing thisConfused
    You will find him ebay as well where he sells his kits.
  • 04-17-2007 12:45 PM In reply to
    • Puncher
    • Top 10 Contributor
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    ChrDH:
    Hi there
    Best regards
     Chr
    He's still here, still using his Dillen monica (although I haven't seen him about for a day or two - perhaps hes on holiday). Drop him a PM and he'll send a kit out (at quite a reasonable price - mine was)Big Smile - payment via Paypal.
  • 04-17-2007 4:24 PM In reply to
    • ChrDH
    • Denmark
    • Posts 493
    Great, thanks. I'll drop him a PM.
    By the way, how difficult was it to replace the capacitors? My soldering skills are very basic, but perhaps I can get my father to help.
    Best regards
     Chr
  • 04-17-2007 5:25 PM In reply to
    • Dillen
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    I'm right here.
    A capacitor kit is available but to be honest, the RL6000 is
    still a fairly new speaker so I'm not sure how much improvement you will notice.
    Replacing the caps is not very difficult, they are fairly large components sitting on a standard one-sided PCB board.
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
