I have in other posts mentioned a few minor trouble with my Beogram 8002 and Beomaster 6000.
The basic fault were that the BG arm would go straight to the end of a record and get stuck. Also a few times when pushing play the arm would go to the begining but then go back and stop instead.
Strange as both Beogram and Beomaster had a newly service by my B&O dealer. The Beomaster has a heating isue but plays good and have no real trouble to speak of.
Now the datalink 7 pin DIN cable for the Beogram is not original and needs 2 pins which are on order.
The weird thing is that I have been using the system for a week or so with no problems what's so ever playing record after record or listning to some radio stations. Even playing a record while writing this!
This got me thinking about the two DIN cables I got from the dealer to use. They have 7 pins normaly but are not marked B&O and I do know that there is difference in the cables for Beogram and Beocord.
The Beocord 9000 is under service so I don't know how it would work.
What is the difference as I forgot?
