Latest post 07-20-2007 5:39 PM by joeyboygolf. 3 replies.
Page 1 of 1 (4 items)
  • 07-19-2007 7:56 PM
    • godlund
    • Not Ranked
    • Joined on 04-27-2007
    • Sweden
    • Posts 17
    Penta 2 display with MX6000?
    Hi!
    I wonder if the display on my Beolab Penta 2 will work when connecting to the Powerlink-output on a MX6000? And what will the display show?
    (Penta is from 1988, MX6000 from approx. 1995)
    Thank you!
    //Johan
  • 07-19-2007 8:01 PM In reply to
    Re: Penta 2 display with MX6000?
    Yes it will work, just remember to chance it to video on the bottom panel.
    shows TV-V.tape-V.aux..... channel and volume. I think
  • 07-20-2007 4:52 PM In reply to
    • godlund
    • Not Ranked
    • Sweden
    • Posts 17
    Nice, thank you!
    Do you know if the MX6000 will work and fit with a motorized stand from a MX5500? The cable socket on the back of the two TVs should be the same, but how about mounting holes etc?
  • 07-20-2007 5:39 PM In reply to
    All MX tv's equipped with the 4 pin stand socket will work with the same stand motor and there are only two mounting plates, one for 21"TV's and one for the 26"TV's.
    It should be noted that the stand socket on the MX4200 and the MX8000 is different. It has 5 pins and requires the motor with a matching 5 pin lead.
    Regards Graham
