Greetings from the U.S.,
I purchased a Beogram 6002 turntable on ebay. As a hint/warning to others looking to ebay for a B&O deal, when the seller says, "Original owner says works fine, but item is being sold as is and has not been tested," and tellingly, "No returns will be accepted," in translation this means that the unit does not work. When I hit the start button the arm tracks out a-o.k., however when I hit stop it only goes so far to the right and stops before going into its docking area behind the aluminum panel. Also when stop is hit, the motor simply whirs and the platter continues to turn. The only way to stop it is to unplug it.
What I'm wondering is: Is it worth the effort and expense to have this unit repaired? I've reconciled myself to the fact that I was taken for $182.50 by either someone who truly didn't know anything was amiss, or someone who did know, gave adequate disclaimers in his item description, and just wanted to dump it on gullible jerk.
