Latest post 08-16-2007 10:03 AM by Seanie_230. 3 replies.
Page 1 of 1 (4 items)
  • 07-18-2007 3:13 PM
    Sorting problem Beoplayer
    Hi all,
    Installed Beoplayer some time ago, but quit using it. The thing is it sorts the tracks within the folders alphabetically!!!  Anything to be done about this??
    Greetings,
    Matthijs.
    PS Also it slams down to one folder tree, very annoyingSad, solvable???
  • 07-18-2007 3:36 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: Sorting problem Beoplayer
    Hi Matthijs. I'm not 100% sure but I think you can drag and drop the tracks into your chosen position.
    Andy T.
    Poor me, never win owt!
  • 07-19-2007 8:17 PM In reply to
    • JOV
    • Not Ranked
    • Joined on 04-28-2007
    • Germany
    • Posts 62
    jandyt:
    Andy T.
    Sorry, but that's not correct. In Folders the tracks are sorted alphabetically...
    Ehh, what would be your favourite order in Folders???
    BTW: What I find very annoying is the fact, that there is no possibility, to sort Albums by Artist Names (First Artist, second Album). If I'm  looking for an album, I naturally search for "Robbie Williams - Escapology" and not just "Escapology"...
    Just my 2 cents...
  • 08-16-2007 10:03 AM In reply to
    • Seanie_230
    • Top 75 Contributor
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    ok i had this problem also and it is very annoying
    from the computer the tracks within the folder are not what beoplayer picks up on if you right click the track and select properties you see more info about the music track.
    if you change all tracks in the foler to
    01 song one
    02 song two
    i will put the tracks into the correct order you want rathan than the annoying way it does it
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
