Latest post 09-24-2007 10:32 PM by Alex Barnett. 14 replies.
Page 1 of 1 (15 items)
  • 07-18-2007 12:11 PM
    • sverreh
    • Top 500 Contributor
    • Joined on 04-17-2007
    • Norway
    • Posts 88
    MPAV9000 - advice needed
    Hello,
    I have recently come across an MPAV 9000 on offer.  Does any of you know if this can be used with an Avant, with or without modification?  If modification is needed, what is required in terms of work , skill and/or funds?
    Thank you
     Sverre
  • 07-18-2007 12:17 PM In reply to
    Re: MPAV9000 - advice needed
    This is a common topic - and it is often the same MPAV9000! Laughing
    On purely economic grounds, the MPAV9000 can only be used with a AV9000 - the ML drivers are in the TV. It is theoretically possible to do something to get it working but with the prices of Ouvertures falling, it is simply not practical and the end result will not be satisfactory. They always look like bargains but are not really!
  • 07-18-2007 12:42 PM In reply to
    • sverreh
    • Norway
    • Posts 88
    Thank you, I'll stick to my 9500 with the converter and save the money for a more prosperous addition to my system.Smile
    Sverre
  • 07-18-2007 12:57 PM In reply to
    • Graeme
    • Joined on 04-16-2007
    • Aberdeenshire Scotland
    • Posts 194
    What is a MPAV9000????????????Unsure
    Cheers Graeme
  • 07-18-2007 1:21 PM In reply to
    Is this still for sale then? would not mind having one for myself!
    It was the Masterpanel AV9000 which looks like an Ouverture - often available cheap on eBay because it won't work with anything but an AV9000!
  • 07-18-2007 4:00 PM In reply to
    • Ulf
    • Top 100 Contributor
    • Germany
    • Posts 665
    The MPAV9000 was the control center with Radio/CD and Tap deck for the 2 Way AV9000.
    Only working with software < 1.2.
    On an AVANT will this Sytem work, but without any Display information like Source and Track.
    It was an cable connectet remote System with audio Sources.
    A beauty system in combination with the famous AV9000, i like these TV.
    Ulf
  • 08-06-2007 7:57 PM In reply to
    Hmmmm... so we think these work with Avants, do we? I have one that I may have to try that with....
    Up til now it has just sat forlorn and unloved in its box....
    :-) Alex
    ________________________________________ Beowulf - the Original music aficionado...?
    Filed under:
  • 08-07-2007 8:54 AM In reply to
    If it doesn't, let me know! I have an AV9000 which would like a friend!! Laughing
  • 09-18-2007 7:22 AM In reply to
    Weeeeeelll.... I will sell it for a reasonable price if it can't be made to work with my Avant or one of the MX's. In the mean time, my MPAV has SW version 1.1, and I have a masterlink cable sitting there idle... so wish me luck, I'm going to flick the switch. If you hear a sonic boom... :-)
  • 09-19-2007 1:32 PM In reply to
    • Ulf
    • Germany
    • Posts 665
    The Masterpanel AV9000 only works in combination with the AV9000 with Software 1.2.
    Sofware above 1.2 doesn't work.
    Really!!!!
    The Software 1.1 at the Masterpanel lost timer function.
    The timer at yaer 2000 did not work.
    Software 1.2 for the Masterpanel is possible.
    Ulf
  • 09-22-2007 4:48 AM In reply to
    It works! Itworksitworksitworks. :-)
  • 09-22-2007 5:11 AM In reply to
    Well done - how have you got it connected and does it work fully?
  • 09-22-2007 12:05 PM In reply to
    -sounds very interesting... do you have full control of the MCP9000 though the Avant? (CD, radio, tape)
    /m
  • 09-24-2007 10:32 PM In reply to
    I do have full control, but as mentioned above, it doesn't seem possible to get the MPAV menus (eg tuning) to appear on the Avant. Which is a pity. It is simply connected via the Masterlink cable, with the Avant set to Option 2, and the MPAV (supposedly) set to option 0.
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
