Latest post 07-19-2007 5:33 AM by ChrDH. 6 replies.
Page 1 of 1 (7 items)
  • 07-18-2007 6:39 AM
    Stuck mute one one channel in Beomaster 6500?
    I just got a Beomaster 6500 in the door. It plays well, but has a mute R-channel on Speaker 1.
    Any suggestions?
  • 07-18-2007 8:29 AM In reply to
    • Kevin
    • Top 50 Contributor
    • Joined on 02-15-2007
    • Moderator
    • Posts 1,256
    Re: Stuck mute one one channel in Beomaster 6500?
    these have a mute relay on the speaker 1 output which are known to give trouble. The contacts can be carefully cleaned but if it´s too far gone the relay will need to be changed.
    cheers,
    Kevin
  • 07-18-2007 9:07 AM In reply to
    Thanks Kevin - I'll give it a look and see what I can do!
  • 07-18-2007 9:10 AM In reply to
    One of mine does this. I use Speaker 2 because I am bone idle!! Laughing
  • 07-18-2007 11:32 AM In reply to
    Yes. It's simple to work around not having MUTE, but also quite nice to be able to quickly dampen the sound when desired. I'll give it a look.
  • 07-18-2007 2:37 PM In reply to
    soundproof:
    I had a dead mute channel on my Beomaster 5000 when I bought it. Some rapid flicking of the mute circuit on and off cured it, and it's been fine ever since. Have you tried doing this? No guarantees that it will work of course, but it seemed to do the trick on mine without any other interventions.
  • 07-19-2007 5:33 AM In reply to
    • ChrDH
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Denmark
    • Posts 493
    j0hnbarker:
    soundproof:
    I have had exactly the same experience with my BM5000.
    Chr.
    Beosound Ouverture, Beocenter 9000, Beovision MX6000, Beocord VX7000
