Latest post 02-29-2012 6:32 PM by williamlarkin. 4 replies.
Page 1 of 1 (5 items)
  • 02-29-2012 3:02 PM
    beocenter 7700 Help!
    Hi,can anyone tell me where to find the voltage switch on the Beocenter 7700? Ijusy bought one from the States and i'm in Ireland. I assume it is set for 120v and the manual says to change the voltage via the switch in the base,but i can't find one! Help! Iwant to turn it on!!!
    Thanks, Bill
  • 02-29-2012 3:33 PM In reply to
    Re: beocenter 7700 Help!
    Hello Bill.  Welcome to Beoworld!
    The voltage selector is indeed on the bottom panel, If you open the 'Programming" cover and locate the Treble control, the voltage adjuster is located directly underneath.  The easiest way to adjust is from underneath.
    Hope this helps.
    Ray
    Я люблю Банг и Oлуфсен
  • 02-29-2012 4:49 PM In reply to
    Hi Ray,
       Thanks for the quick reply but maybe i'm a bit thick. Do you mean i have to unscrew the programming panel and lift it up to find the switch? I can't see any way to access it from beneath the machine.
    Thanks, Bill
  • 02-29-2012 5:44 PM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    Do American units have a voltage selector?
    Olly.
  • 02-29-2012 6:32 PM In reply to
    I hope so! I would have thought the purpose of a voltage selector would be they wouldn't need a special model for the U.S.
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
