Latest post 02-28-2012 10:48 AM by Søren Hammer. 1 replies.
Page 1 of 1 (2 items)
  • 02-28-2012 8:49 AM
    Beocenter 3300 Cartridge and Tonearm replacement?
    Hi Guys,
    I am new to this forum but I am currently reviving a BC3300 and need some advice/info.
    When I got the center it wouldn't power up, simple problem the Off mechanism jams so after stripping and releasing everything works fine. Problem 2 however looks bigger! The stylus was bent so I now need to purchase a new one. Only the MMC4000 seems to be rather pricey.Does anyone know of a cheaper replacement which fits or failing that can I change the tonearm?
    Cheers
    Jamie
  • 02-28-2012 10:48 AM In reply to
    Re: Beocenter 3300 Cartridge and Tonearm replacement?
    Hello Jamie
    You can use any MMC20 (S/E/EN/CL), SP15 and the older MMCxxxx (3000/4000/5000/6000). Be aware that there is a slight chance of some units to have age-related problems like hardening of the suspension inside.
    There is also the possibility of getting your cartridge retipped by Axel Schürholz at http://schallplattennadeln.de/
    He will replace the suspension an stylus with new components and make your cartrigde sound like a new one.
    Cheers,
    Søren
    Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
