1st March February 2012
Latest post 02-29-2012 10:19 AM by GTS. 20 replies.
02-25-2012 2:28 AM
GTS
![](/utility/anonymous.gif)
![Not Ranked Not Ranked](/Themes/beotheme1/images/rankicons/rank0.gif)
- Joined on 02-25-2012
- Posts 9
![Bronze Member](/Themes/beotheme1/images/roleicons/8373aae9-2be6-4a12-8c67-ab927ce1557e.gif)
So;
After looking for a second set of Pentas, I negotiated (what I thought was) a fair price with an eBay seller and a pair of Penta 1's arrived recently.
Regrettably the midrange drivers weren't so much "professionally refoamed" as promised, more "refoamed by a blind man using too much glue"... visually the job is horrific and one voice coil actually scrapes. Ideally the whole thing needs to be redone, though I'm wondering if simply attempting to remove the glue from the cones is likely to damage them?
Is there any way to test the displays without connecting them to B&O equiment? (Apologies if I'd missed this somewhere else in threads, I couldn't find much).
In the event these speakers prove unsalvageable (there's some shipping damage to the stainless, unfortunately) what's sellable asides from the amplifiers and the displays?
Step1
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.88.68/avatar.jpg)
![Top 75 Contributor Top 75 Contributor](/Themes/beotheme1/images/rankicons/rankTop75.gif)
![Male Male](/Themes/beotheme1/images/rankicons/GenderMale.gif)
- Joined on 07-06-2008
- Manchester
- Posts 961
![Gold Member](/Themes/beotheme1/images/roleicons/d27431af-8474-494c-aeb0-d1cede4cb008.gif)
Peter:
You do really need a piece of B&O with the Speaker link connection - however it sounds to me that you have been sold a pup - I would attempt to return these.There are lots of Pentas out there - these days, I would strongly suggest sticking to the Penta 3. You can still, last time I looked, get new midrange units.
Someone told me B&O charge an extortionate amount until you trade your old mids in, so if true it sounds like they are running out of stock!
But I agree if you can send these back, especially with the shipping damage on top!
GTS
- Posts 9
I should be honest - I bought my other Pentas at extremely good prices and didn't do too badly on these. Whilst the seller didn't take them back, he was good enough to offer a partial refund. So I have two 'good' pairs (1x Penta 2, 1x Penta 3) requiring slight refurbushing and one 'not so good' pair (1x Penta 1) for whom I've got to decide quickly whether I repair and keep them, do something wild with them and keep them or part them out and cut losses. My partner, well, she likes the sound of the pair that's currently connected but would like me to do something constructive with the other four in short order...
I don't like the displays on them and am keen to work out if they work or otherwise to gauge whether they can be sold or not. I'll likely remanufacture an opaque black (or very dark grey) lens cover. The 2's appear to have had the displays upgraded to some sort of two-line LCD and I'm honestly just keen to see what happens when it's turned on.
So we're currently at 'sell the 1's and possibly the other displays' with the 1's either in parts or as complete units. If selling as complete units I'd not feel comfortable passing them on with the midrange units in that condition. I'll post a pic later... If they can be 're refoamed' I'll order rings.
GTS
- Posts 9
OK! Four Penta's worth of midrange drivers (that's 16 of them!) removed, old foams out of my Penta 2's and 'new, professionally refoamed' kit off my Penta 1's... what a disaster! I had thought some of the horror stories on refoaming on this forum to be a bit extreme, but no - completely possible!
What a sad way to treat a lovely pair of speakers... one of the speakers was completed with way too much glue, the other with clearly not enough. It'd seem no pressure was used when curing the glue either - a very 'lumpy' finish. PVA (woodworker's glue) was used and let me assure anyone considering using this on their speakers and thinking about keeping them well into the next refoam... don't! It's absolutely awful to get off on a paper cone! There appears to be no way of doing this without some degree of cone damage. Just use cement!
Two of the drivers will simply need to be replaced - 1 having been used when the cone clearly wasn't centered, the other from simply too much glueleading no way to get rid of it without taking out an amount of the cone. Most suffered some light surface tearing and are now cosmetically fine (after very light sanding) though T/S parameters are likey to have changed... not good. The one that needs to go still looks 'normal' but it'd rather it play 'normal' too.
I'll post some pics after cleaning up the baskets and vacuuming everything clean.
Those having refoamed their own - did you shim? I'm headed that way...
Of (trivial) interest it'd seem B&O went from philips screws on the Penta 1 to Torx screws on the 2/3's...
Leslie
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.01.24.24/avatar.jpg)
![Top 50 Contributor Top 50 Contributor](/Themes/beotheme1/images/rankicons/rankTop50.gif)
- Joined on 05-07-2009
- Netherlands
- Posts 2,201
GTS:
No I did not and never will at leat not for these type of drivers. I will consider using the batterie method for the next refoaming job, but cutting out the dustcaps, no way.
Looks yours has been done by a boatworker with two left feet!![Big Smile](http://forum.beoworld.org/emoticons/02.gif)
Just finished another 8 and will connect them later this week! Will let you hear about the results....
![](http://forum.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.01.24.24/Penta-mr01.JPG)
B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
Beovirus? What's that?
Beobuddy
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.25.94/avatar.jpg)
- Joined on 04-18-2007
- Posts 1,582
![Founder](/Themes/beotheme1/images/roleicons/6f51347a-6d4c-4ff4-9d2e-4e3705076d55.gif)
@ Leslie,
Did you use rubber instead of foamrings?
It's a know fact that rubber lasts longer, but sounds different.
Leslie
- Netherlands
- Posts 2,201
Foam. Have been using rubber before but it's quite difficult to handle!
Have been talking with Martin about this refoaming/shimming thing and my or better our conclusion is, if you don't have the skills or you have two left hands or feet let a pro do the job!
Beobuddy
- Posts 1,582
Time is a important factor, take your time with refoaming. But that's something you already know ![Wink](http://forum.beoworld.org/emoticons/05.gif)
I've done a set of CX's 2 weeks ago. And the result was positive despite that I'm not a real supporter of refoaming.
The tolerance is close to zero when it comes to the cone.
GTS
- Posts 9
Leslie:
Would imagine this changes the T/S parameters also, starting with Fs - probably not ideal.
GTS
- Posts 9
Still scraping and dissolving glue on the frames of the Penta 1 midrange (the 'professional' refoam)... what a mess. The baskets are glass-filled nylon and end up looking a little worse for wear... until a surface color's applied, then we're getting somewhere - cosmetically original and a nice, flat surface to glue onto.
Quick question on just how much to remove on the cone side:
Getting rid of the foam leaves the old glue residue on the cone. Removing that much tears a thin surface layer of the cone, leaving it on adds where the cone's least rigid and neither option makes doing it 'next time' any easier...
...so who's doing what? Leaving a bit of old glue and gluing on top of that? Scraping that off and thinning out the cone for better attachment?
Jeff
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.01.52.36/avatar.jpg)
- Joined on 03-01-2010
- USA
- Posts 48
GTS:
Leslie:
True, but if for a midrange that is operated fairly far above resonance, maybe not as much of an issue? But the upper response of the driver, how smooth, how extended, what rolloff, etc. is definitely a function of the edge termination. Sound propagates radially out from the voice coil, think of a long string or spring as in the old physics classes demostrating standing waves. The manner of termination of said string or spring, into a solid object, into a different value spring, into a damped system, will radically alter the standing wave. Same happens for speakers, when originally designing a driver the engineer will choose the surround and cone thickness, etc. to achieve a certain response (or just wing it and see what happens). The speaker system designer will look at the behavior of the driver at low and high freq extremes when designing a crossover. If the edge termination via the surround changes the upper freq response the crossover will most likely be misaligned.
Of course, if the driver is operated over a range well short of the low and high freq limits any change will be less critical. Not knowing the xover points on the Pentas I can't begin to hazard a guess. But I'd generally try and redo the surrounds with as close to OEM as possible.
GTS
- Posts 9
All valid points Jeff - a great response. I agree that Fs as a lower frequency limit isn't a primary concern, though as a physical property it affects a great deal.
The notion of valid end termination gives further ammunition to the previous question though - loading a cone up with glue at the periphery will have a more significant effect than the same mass added about the center, though we can't completely remove glue at the join with each refoam or a few decades from now we'll have a structural mess and/or little left to attach to.
So what's the smart move? The most I can surmise presently is that there'd be a good tolerance (10-20%) in Fs, a good portion of it in termination and cone mass, primarily if everything's consistent we're onto a better solution than none at all...
To remove all glue traces or to build on top of what's there, cleaned as best possible?
GTS
- Posts 9
Finally cleaned up 16 midrange drivers. Cleaned the original foams off the Penta 2's and finished cleaning a poor refoam off the Penta 1's. Some observations...
Big difference between between cleanup of the original job and the poorly-done refoamed drivers - the latter took three times as long and, quite frankly, are a bit worse for wear. I guess if you're confident doing it, don't - especially if keeping the same speakers into the next refoam.
Choice of glues... critical. The orginal stuff left a thin film of itself. The 'refoam kit' glue is clearly some sort of PVA, and the application went beyond the original glue line (as mentioned here http://www.decware.com/newsite/refoam.htm). Big mistakes both. The glue clearly binds differently to a paper cone and going further into the cone's a big no-no, get the right sized surrounds. The only way to get this mess off is to tear off a surface layer of the cone. Not ideal. The two local 'professionals' suggest a waterproof woodworking PVA - 'a PVA that doesn't dry brittle', but neither business has actually had to refoam a set of speakers that they'd originally refoamed. I'm no closer to knowing what I shouldbe using for my own refoam.
Another observation - the speakers that have had a poor refoam have suffered a bit of misalignment stress in the few months use since the their refoam. Sufficiently so that they'll need more care in alignment - these definitely will be shimmed.
It really is a task that requires care and thought.
A battery seems a bit crude for a 'second rate' approach - wouldn't it be a little more elegant to turn a PC speaker out into a crude signal generator or similar?
If anyone's got detailed thoughts on a refoam adhesive, let me know.
Leslie
- Netherlands
- Posts 2,201
Could you colo(u)r up your story a bit by adding some pictures. You know the frase "a picture is worth a thousand words". I'm specially interested in the shimming part of your Penta midrange, cutting of the dustcap, shimming, replace a new one etc.
Jeff
- USA
- Posts 48
GTS:
I would imagine a shift of Fs might not be as troublesome as a shift in Qts, depending on how small the enclosure is.
You make a good point re the stiffness of the glue. There would be a difference between a surround terminated with a soft, pliable rubber cement type of glue vs. the PVA hard/stiff glue many recone kits come with, regardless of what that may do to the ability to recone.
Hopefully, if they are made correctly with the right materials, new foam shouldn't suffer the foam rot of the originals. I have a friend who works in the speaker industry, and for a long time driver makers knew that there was a fungus that attacked foam but they were not very forthcoming about it, in many cases when a solution had been discovered certain large speaker companies leaned on the driver makers not to inform competitors of it. From what he described the whole situation sounded kind of sordid. That problem should be solved now, but maybe not depending on who made the replacement surrounds. I can imagine some low end offshore makers might not use the newest formulations, particularly if they are patented. I've never owned a pair of speakers with foam surrounds before the CX50s, so hadn't experienced the rot although I knew it was an issue.
GTS
- Posts 9
Leslie:
(Nice pickup on the English spelling!)
Pics? Sure.
Here's what they look like with the original surround removed off my Penta 2's. Note the nice, even bead.
This is one of the better drivers off my Penta 1's after a not-so-good refoam. Note the amount of glue application. You can just see where the original glue line was.
And this is one of the worse drivers off my Penta 1's. Note the poor aplication - some places have glue, some not. The glue, or the interaction between the glue used, the paper and the foam has neatly torn out some of the driver surface (which on some refoam jobs is normal) inboard of the cone perimeter (which is not).
It's taken a lot of work to get the 1's this far. The stresses imparted by not-quite-correct gluing has given rise to some solid misalignment - yes, there are axes in which you can push the cones inwards and there's no mechanical contact, but compared to the Penta 2 set, it's not pretty. And to be frank, given that I take pride in these speakers (as we all should) I'm wondering what I can do to bring them back costmetically also (some pro shops actually paint cones as part of reconditioning...)
Not sure what I'm going to do with them now.
First off I'll to borrow a multimeter tonight to see if why of the coils are open (and thus completely unsalvageable). If we get to the stage where there's too much to invest here, I might just part the speakers out.
GTS
- Posts 9
Latest...
Tested every coil for impedance. No open circuits - good news!
Interestingly the coils all come in at 2.9-3.0 Ohms for the Penta 1's, 3.1-3.2 for the Penta 2's. Possibly an age thing.
Ordering foam rings now.
Page 1 of 1 (21 items)
