Latest post 02-25-2012 8:44 AM by beoinbuff. 15 replies.
Page 1 of 1 (16 items)
  • 02-24-2012 5:18 AM
    • Samir
    • Not Ranked
    • Joined on 05-07-2011
    • Paris, France
    • Posts 8
    Non-B&O Subwoofer for Beolab 3's ?
    Hello Folks
    I am following this forum for a looong time, but this is my first post here..
    I know, this is another post on this subject (subwoofer), and i am aware of what has been written here about it.
    My question is : do you guys have any feedback to share about coupling a Sub to your Beolab 3's speakers ?
    I am very interested about your experience on a configuration like : B&W Pv1D + Lab 3's ...or another non B&O sub..
    I already had a Lab 2 a few years ago, and i did not like it so much ... also, the Lab 11 seems a little weak for deep bass, even if it is B&O "compatible". From what i know, it seems that Lab11 it is better to use with Lab6000 or 8000, rather than Lab 3's.
    I am really considering tio buy the B&W PV1D to use with my Lab 3's... Is it worth it?
    Best from Paris
    Samir
    Beosounds Ouverture, 4, 9000 - Beolabs 8000, 4000, 2500, 3500, 4500, 3 - Beomaster 6500- Beocom 6000- Beotalk ... no more Video products (Avant 82, Mx4000, AV9000). My Bl6000 + Bl2 died in a flooding .. but they still powered on after 24 hours under water (!) ... i need a subwoofer
  • 02-24-2012 5:40 AM In reply to
    • mbee
    • Top 50 Contributor
    • Joined on 04-18-2007
    • Paris, France
    • Posts 1,133
    Re: Non-B&O Subwoofer for Beolab 3's ?
    As nobody has already been able to listen to a PV1D, the answer is complicated... But the PV1 was a good match.
    For me there is a big drawback when using non-B&O sub : on a B&O sub, you get Powerlink outputs that filter the low frequencies of the sub. You then get more bass, but also, and it's very noticeable, better mid and highs! I think that you heard it with the BL2. That's not the case with a non-B&O sub.
  • 02-24-2012 7:07 AM In reply to
    • Samir
    • Not Ranked
    • Paris, France
    • Posts 8
    yes , that's what i thought.
    In other hands, BW PV1D is cheaper, more powerful and can be used with any another system (TV..). Also, do you think the Lab11 are powerful enough ?
  • 02-24-2012 7:12 AM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    I think one vital piece of information you left out was the audio master. Which are you using Samir?
    Evan
  • 02-24-2012 7:27 AM In reply to
    • Samir
    • Not Ranked
    • Paris, France
    • Posts 8
    Hi Evan
    BS4 or Beomaster 6500
  • 02-24-2012 7:34 AM In reply to
    • mbee
    • Paris, France
    • Posts 1,133
    First : what didn't you like about the BL2?
    I'm not sure the BL11 will be good enough with BL3. I think that it's main advantage will be to "deliver" the BL3 from the bass, thus enabling more subtle mids and highs, but basically, a BL11 is just 2 bass drivers from BL3, it doesn't go very deep... I've talked to dealers in Paris at the launch of the BL11, and nobody had it on display with BL3, they all said it was useless...
  • 02-24-2012 7:41 AM In reply to
    • Silou
    • Top 500 Contributor
    • Joined on 08-10-2007
    • Switzerland
    • Posts 241
    • Gold Member
    Maybe the Revox sound S bass 02
  • 02-24-2012 8:12 AM In reply to
    • Samir
    • Not Ranked
    • Paris, France
    • Posts 8
    @mbee
    what i did not like was that i felt it was way too powerful Geeked.. i spent my time playing with my remote, because they "boomed" too much, like an earthquake. But maybe because I did not calibrate them properly (setup & placement).
    About dealers in Paris, they told me exactly the same..
  • 02-24-2012 9:23 AM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Samir,
    mbee has presented a serious topic. A primary reason for adding a subwoofer is for redirecting low tones away from your main speakers (BL3s). The B&W PV1 does not have a pass through, which means it will not do any filtering for your 'Labs, reducing the overall benefit of adding a sub.
    Find a suboofer that has inputs AND outputs. Your signal chain will start with your audiomaster, both channels to the sub and then both channels will go from the sub to your 'Labs. All of which will be a 'line-in' setup, no longer Powerlink.
    Secondly, ask your local dealer for an in-home demo of the BeoLab 11. If you find the 2 was too powerful, you may end up preferring the less powerful 11. Otherwise, look for a sub that has filtering capability.
    Evan
  • 02-24-2012 10:00 AM In reply to
    • Samir
    • Not Ranked
    • Paris, France
    • Posts 8
    Thank you very much Evan
    With my limited knowledge, i came aproximately to the same conlclusion.
    And I was already trying to find it on google ("active Sub with output signal" or "active Sub with pass through")  ).So i guess, i have 2 options :
    - Get a B&O sub (BL2 or BL11) , maybe BL2 should be best choice  => full B&o integration
    - Get a Sub with output signal => in fact, more versatile since you can use it with another equipment
    If you guys have any idea of a non-B&O Sub that does match these requirements, I woudl greatly appreciate
  • 02-24-2012 10:14 AM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Immediately I think of the Fostex PM-SUBn. It has in and out, with gain controls. It's also pretty cheap compared to most any other sub. If I remember correctly, it is relatively weak, approx 70w. But it I a sealed cabinet so should fare well regardless.
    There are many others. I'll post any if I think of them.
    Evan
  • 02-24-2012 1:30 PM In reply to
    • Samir
    • Not Ranked
    • Paris, France
    • Posts 8
  • 02-24-2012 3:27 PM In reply to
    • Samir
    • Not Ranked
    • Paris, France
    • Posts 8
    or maybe a beolab1, or a beolab2,  to stay full B&O.. which is my love
    Who knows ?
  • 02-24-2012 3:30 PM In reply to
    • Samir
    • Not Ranked
    • Paris, France
    • Posts 8
    I need a Sub
    Sad
  • 02-24-2012 5:11 PM In reply to
    http://www.bowers-wilkins.com/Speakers/Home_Audio/Subwoofers/PV1D.html
    PV1 has a low pass filter
    Borja
  • 02-25-2012 8:44 AM In reply to
    I have this one with my 4000s: http://velodyne.com/subwoofers/shop-by-series/eq-max-series/eq-max-8.html
    Not the prettiest thing but it sounds good and equalization feature worked very well
    Beolab 5, beolab 3, beolab 4000, beosound 9000
