Latest post 02-26-2012 6:30 PM by kai. 5 replies.
Page 1 of 1 (6 items)
  • 02-23-2012 7:21 AM
    • kai
    • Top 500 Contributor
    • Joined on 11-16-2008
    • Posts 81
    Extending masterlink via cat 6
    I have a set up and need to extend the cable from a junction box the distance is about 40m, I have some cat 6 cable is it possible to use this cable as the masterlink cable is expensive
  • 02-23-2012 7:41 AM In reply to
    • zazouzt
    • Joined on 04-17-2007
    • near Strasbourg/France
    • Posts 123
    Re: Extending masterlink via cat 6
  • 02-23-2012 8:57 AM In reply to
    Sorry, this will not work. You will need Cat7 to complete the run with the appropriate adaptors. You need the braided shield that isn't present in Cat6.
    There is scarcely anything in this world that some man cannot make a little worse and sell a little more cheaply. The person who buys on price alone is this man's lawful prey. - John Ruskin
  • 02-24-2012 4:43 AM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    TripEnglish:
    The difference in bandwidth between Cat 6 or Ca 7 is not important, if you want to use
    Cat x instead of original ML.
    It's the layout of the shielding/screening of the cable that matters!.
    To replace an original ML cable ONLY cables described as "S/FTP" =
    "S
    hielded(Screened) /Foiled Twisted Pairs" have sufficent shielding for the
    two Twisted "Audio" Pairs (carrying the BALANCED ANALOGE signals of ML)
    to avoid crosstalk between these pairs and the 3rd Twisted ML "Data" Pair.
  • 02-24-2012 9:08 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Ebay Germany seems a lot cheaper than ebay.fr....
    Search for masterlink rj 45 on ebay.de
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 02-26-2012 6:30 PM In reply to
    • kai
    • Posts 81
    Thanks for the replies guys, I will have a look at that cable, I have done this in the past where the customers house was wired with Bose cable, we checked it out and successfully used that all we did was use junction boxes with ml ends onto the cable 7 years on still working. I only need to run the cable for Audi so will look at Vienna's suggestion
    Kai
