They did develop a new touch pad that should have solved this issue. If you have been given a new unit, that new unit should have a new warranty so you shouldn't have an issue getting the touch panel replaced. In any case if you have had three repairs and a replacement I am sure B&O would be very keen to look after you and cover and work needed to get the product operational for you.
BV7-40MK4BR,7-32,6-22,6-23,6-26,BSnd5,9000,BLab9,3,4000,2,BCom2,6000,Btalk1200,LC2s,Lutron
