Latest post 02-21-2012 3:49 PM by applemac1. 6 replies.
Page 1 of 1 (7 items)
  • 02-21-2012 1:11 PM
    Beovox cona
    Can a beovox cona be used through other amplifiers other than bang and olufsen being that its passive. For example is it possible to wire it to an amp and the the cona wired to two cx100.
  • 02-21-2012 3:05 PM In reply to
    Re: Beovox cona
    Yes. You connect the Cona to any normal passive amp and then connect the speakers to the Cona. The Cona has a crossover inside and sends the higher frequencies to the smaller speakers. Connection to the Cona from both the amp powering it and to the other speakers is by binding posts underneath. I had one for several years with some CX50s and then later for a bit of a laugh with my Beomaster 8000 and some Beovox Pentas!
  • 02-21-2012 3:32 PM In reply to
    • Stonk
    • Top 50 Contributor
    • Joined on 04-16-2007
    • Marlow, Bucks, UK
    • Posts 1,688
    Re: Beovox cona
    There's a nice one on eBay at the momentStick out tongueDevil
    If you think nobody cares, try missing a couple of payments.
  • 02-21-2012 3:43 PM In reply to
    Re: Beovox cona
    Great, one last question what is the type of input to the cona is it phono line in?
  • 02-21-2012 3:45 PM In reply to
    Re: Beovox cona
    Eh? It's just a normal speaker output from an amp!
  • 02-21-2012 3:49 PM In reply to
    Re: Beovox cona
    Yeah John just realised was in your original answer binding post. Thanks fr the help
    Re: Beovox cona
    Is there Stonk, thanks ill have a look. Thanks for your reply
