Hello!
I just got this problem with my avant:
From mains powered on, it can be switched on, everything is allright, picture 100% sharp and clear, no flyback lines.
Sound is okay, crisp and no hisses.
when i want to change mode(VCR, Camcord), or switch channels, it just freezes, for example it changes the channel, sound is okay, but pciture appers 20 seconds later.
contorls dont work, e.g. if i want to change volume it lags, minutes later it appers on the little red display.
anythng pressed on the remote, the little red lcd becomes more lit up(so active, that command is recived).
has anyone met this problem before?
my set has never been serviced, it's 100% original.
Greetings
widerstand
