Latest post 02-16-2012 12:06 PM by tournedos. 3 replies.
Page 1 of 1 (4 items)
  • 02-16-2012 8:44 AM
    • scott451
    • Top 500 Contributor
    • Joined on 05-22-2007
    • Paris, France
    • Posts 132
    bv7-40 & dynamic range compression
    hi,
    i just noticed that my set top box has an option for dynamic range compression - options : max, average, off.
    the settop box is connected to my bv7-40 via hdmi.
    is something i should leave on, or will it interfere with bv7 signal processing ?
    thanks !
    - scott
  • 02-16-2012 11:46 AM In reply to
    Re: bv7-40 & dynamic range compression
    Without knowing what it exactly does, it is hard to say - but generally having several devices in a chain doing something to the picture is not a good idea. The BS3 is probably better at it anyway!
    -mika
  • 02-16-2012 12:01 PM In reply to
    • Style
    • Not Ranked
    • Joined on 08-01-2011
    • Posts 40
    It is about audio compression, not anything to do with picture
  • 02-16-2012 12:06 PM In reply to
    I would definitely have it off then, no matter what it is connected to!
    -mika
