Latest post 02-17-2012 10:39 AM by wake76. 2 replies.
Page 1 of 1 (3 items)
  • 02-16-2012 7:05 AM
    • wake76
    • Not Ranked
    • Joined on 09-11-2008
    • Posts 4
    Beosound 3000 CD clamp issue
    Hello,
    Does anyone have experience of this type of issue?
    When pressing LOAD key the CD clamp opens and closes itself 2 times (open-close-open-close) and stays closed...? I used to have CD clamp issue with Beosound Century (it stopped on the midway when opened it). and I managed to fix that by disassembling and assembling the gearbox again.
    Would there ve similar issue with Beosound 3000? if someone has forced the CD clamp to open and gearbox is on wrong position? just a guess.. but also sometimes... every 20th time the CD clamp works normally.
    please share if you have experience with this type os stuff. thanks!
  • 02-16-2012 12:02 PM In reply to
    Re: Beosound 3000 CD clamp issue
    Normally a dirty Micro switch
    Regards Graham
  • 02-17-2012 10:39 AM In reply to
    • wake76
    • Not Ranked
    • Posts 4
    Thank you!
    I cleaned the micro switch and it is working well now!
