Latest post 02-16-2012 11:23 AM by Cyprus16M. 5 replies.
Page 1 of 1 (6 items)
  • 02-16-2012 6:30 AM
    How to change the Frets of my BeoLab9???
    Hey Guys,
    I recently got myself some new coloured frets for my BeoLab9. Could somebody guide me on how to change them because i have no idea how to do it? Cheers:D
  • 02-16-2012 8:11 AM In reply to
    Re: How to change the Frets of my BeoLab9???
    It has been awhile since I changed mine, but.....
    on the top, behind the tweeter/ALT unit there is flat piece that if I remember correctly is somewhat flexible. Use a screwdriver to pry it up and off. Once it is off the screws that hold th ALT on will be revealed. I think there were two. Remove those and lift the ALT unit off. There will also be a connecting cord that needs to be disconnected. It just unplugs. After that it is just a matter of sliding the old grill up and off. It will be tight and something will need to be inserted carefully between the bottom of the grill and the black base of the 9 to get it started.
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 02-16-2012 8:31 AM In reply to
  • 02-16-2012 11:23 AM In reply to
    Claudiu thank you for the attachment much appriciated aswell. CheersSmile
    Razlaw much appriciated, ThankyouSmile
    Thank god they have created BEOWORLD forumSmile
