I found this MCL 2P - amplifier, including two speakers and 2 other elements (a 2020 and a 2046) in the house we just bought. I'm not familiar with the system.
I don't especially want to have a home audio system, since we're not going to use the house as it used to be used.
What I would like though is to use the amplifier and speakers to connect the to my computer and just play loud music, simple as that.
For this I have two questions:
1. B&O seems to work with a special kind of audio cable, is it possible to connect a normal jack to the amplifier?
2. does my idea make any sense, cause I don't find a volume control on the amplifier. How will I be able to control the volume?
Thanks a lot if anyone can answer my dummy questions...
