Latest post 02-13-2012 6:11 AM by Leslie. 1 replies.
Page 1 of 1 (2 items)
  • 02-13-2012 2:57 AM
    • Dusty
    • Not Ranked
    • Joined on 02-13-2012
    • USA
    • Posts 1
    LC1 Controllers (x2)
    Hello All,
    I am new here and looking for some advice.
    I am in the USA and have two (2) LC1 Controllers that I am thinking about selling.
    They look just the the unit in this post, only perhaps in a little better cosmetic condition:
    http://forum.beoworld.org/forums/p/40831/339260.aspx#339260
    I need some advice on where the best place to list them would be...here, Ebay, etc.
    I would also like to know what the minimum I should be asking is (USD)?
    I hope some of you can offer me some guidance.
    Thank you in advance,
    Dusty
    Filed under:
  • 02-13-2012 6:11 AM In reply to
    Re: LC1 Controllers (x2)
    Eaby is unpredictable Dusty! When you're lucky they will bring 100$ each, but it can be less. The results also depends on which Ebay site (UK,DE etc.) you gonna put them on and off course the condition in which these things are . Wish you all the luck selling them. Btw, LC2's are much more valuable.
    Edit: Put the LC1's separately on Ebay!
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
