EDIT: Sorted, but please see 2nd post ;)
Hi there!
I recently aquired some BeoLab 5's and BeoLab 3's.
I have only hooked up the BeoLab 5's so far, and as I was warned here on the forum, I notice that the BeoLab 5's :
a) Have to be turned on and off manually with the Beo4 :(
b) Take a while to output sound as soon as it receives audio input.
c) Stop transmitting audio output as soon as there is no noise detected after a certain amount of time (
+-10 sec).
I have been advised that I can use a trigger cable to solve the problems above. Is that correct?
I understand the trigger cable needs to be modified to step down 12V to 5V which the BeoLab 5's require.
If someone could kindly clarify the following for me I would greatly appreciate it.
Firstly:
What does the trigger actually do? Does it simply turn the speaker on when it
receives a trigger signal (voltage), and turn it off when it goes off?
Secondly:
- What cable should I use to connect them? Right now I am using a LINE -> LINE cable to connect to the pre-out on the amp with no trigger, and am getting the problems mentioned above.
Should
I use a LINE + trigger --> LINE cable? Or instead, use a LINE + trigger
--> Power Link cable? (One end into BL5 and one end into the Onkyo Amp). Is Power
Link cable necesary in order to turn the BeoLab 5's on and off using the trigger, and not LINE?
If
anyone could be so kind as to advise along with what I will need and any
tips, I would really relaly apprecaite it. I'm having a bit of trouble
understanding the danish website even with google translate, and my head
is spinning in circles trying to get my head around this.
http://translate.google.com/translate?u=http%3A%2F%2Fwww.hifi4all.dk%2Fforum%2Fforum_posts.asp%3FTID%3D71963%26TPN%3D1&sl=da&tl=en&hl=&ie=UTF-8
Thank you very much
P.S. Where do I get the cables from? (e.g. PowerLink connection, LINE connection, trigger connection etc.)
