Latest post 02-12-2012 4:47 AM by Blackrix. 1 replies.
Page 1 of 1 (2 items)
  • 02-11-2012 5:18 PM
    beocenter 9000 compatible with beolink passive type 1658?
    i need to know if it possible to connect a beolink passive type 1658 with a beocenter 9000? i do have the beolink 1000 controller. thanks
  • 02-12-2012 4:47 AM In reply to
    Re: beocenter 9000 compatible with beolink passive type 1658?
    I would use an MCL2A kit. This is the original linksystem for your BeoCenter 9000. To use a BeoLink Passive on your BeoCenter 9000 you first need a BeoLink Converter to be able to connect ML to your BeoCenter and I am not sure if this will work 100%. An MCL2A can be connected directly to your BeoCenter and is the easiest and cheapest solution.
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
