Latest post 02-12-2012 8:10 AM by dennis2544. 5 replies.
Page 1 of 1 (6 items)
  • 02-11-2012 8:56 AM
    No sound with Appletv2 and beosystem2/BV4
    I'am stuck! I bought a Appletv2 thinking i could connect it in the same way as i connected my PS3.
    The ps3 is connected via HDMI/DVI cable to the BV4, The sound goes via optical out, via a converter to coaxial in (SPDIFF) in the beosystem2.
    This works fine, like i said..... The funny thing is, if i connect the Appletv2 exactly the same way, the picture is kristalclear, but there is no audio at all...... Maybe i need another converter?
  • 02-11-2012 11:01 AM In reply to
    • madskp
    • Top 500 Contributor
    • Joined on 11-06-2007
    • Denmark
    • Posts 111
    • Gold Member
    Re: No sound with Appletv2 and beosystem2/BV4
    Is the apple tv updated to the newest software version (4.4.4) ? I think there has been some problems regarding sound from the optical out.
    Try also the settings mentined in this link http://support.apple.com/kb/TS3789
  • 02-11-2012 12:28 PM In reply to
    Yep, version 4.4.4 is on..... The other thing didnt help.....
    According to a B&O dealer i needed to buy a gefen digital-analog converter and play the audio sterio via the a aux conection on the B&O 9000 ..... So i did..... 94 Euros!  Via list on the beo4 I inserted the function AV. If I play the Apple tv (on DTV) i can now press list AV, then radio, and then i have the sound from the radio while watching the ATV..... Problem is now arising: If i press the a aux button on the beosound 9000, the screen goes black! Anybody an idea?
  • 02-11-2012 8:36 PM In reply to
    dennis2544:
    I hope someone can find the right solution for you ... the above approach seems to rely on timing and tricking the systems.
    I think the approach relies on having the BS 9000 playing AUX from the ATV2 audio and then starting access to the ATV2 video on the BV4 and then getting the BV4/BS2 to access audio on the MasterLink.
    Can you try programming the Beo4 to issue an [A.AUX] command so you are not messing around with the [RADIO] source ?
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 02-12-2012 5:26 AM In reply to
    • hfat
    • Joined on 05-18-2010
    • Austria
    • Posts 176
    • Gold Member
    Hello,
    Try using the Link-AV (via List) command on the Beo4
    hfat
  • 02-12-2012 8:10 AM In reply to
    Ha! problem solved, i have to press list/av/a.mem ..... then the sound of aux is played with the dtv selected on the BV4 !
    Thx for your replies!
