Latest post 02-11-2012 12:24 PM by Seanie_230. 5 replies.
Page 1 of 1 (6 items)
  • 02-10-2012 4:20 PM
    Beo Vision 7 mk IV and My sky
    Hi hall,
    I'm new in this forum, I'm  italian boy and I don't write a good english...sorry.
    Today I have try to connect my sky HD to my beo 7 with a hdmi-hdmi cable +dvi adaptator but i see nothing black screen.I try to connect my notebook and start.I dont' understand someone help me plase?
    Thnks a lot
    Danko
  • 02-10-2012 5:15 PM In reply to
    Re: Beo Vision 7 mk IV and My sky
    Mk4 BV7 should only need HDMI- only the Mk1 and Mk2 needed a DVI connection?
    BV7-40MK4BR,7-32,6-22,6-23,6-26,BSnd5,9000,BLab9,3,4000,2,BCom2,6000,Btalk1200,LC2s,Lutron
  • 02-11-2012 5:29 AM In reply to
    My Beo vision have a one DVI connection and nothing HDMI.But I dont't understand how config for my sky hd.There are some trouble with my sky hd?Some experiene?
    Thanks.
  • 02-11-2012 7:10 AM In reply to
    • JC
    • Top 100 Contributor
    • Joined on 04-16-2007
    • Yorkshire / UK
    • Posts 621
    dreamer:
    Thanks.
    This indicates that your TV is a MK1 or MK2 version not a MK4.
      Jonnie
  • 02-11-2012 11:32 AM In reply to
    • paul
    • Top 500 Contributor
    • Joined on 09-10-2009
    • dublin
    • Posts 130
    • Gold Member
    As far as I know, ALL Mk4 7-40 TVs are HDMI.......so you may have Mk1 or Mk2??? Check it on back/Reverse of TV...its  written behind a panel on back.
    BeoVision 7-40 MKIV with BeoLab 7-4 Vertical speaker, BeoSound 9000 CD/Tuner, Speakers are a pair of  BeoLab 5 in Black with a pair of BeoLab 4000 as rear speakers, and in bedroom BeoCentre 6-26 with BeoLab 8000's. Both the Kitchen and bathroom have Beolab3500's. BeoCom 2 and BeoCom 5 phones. Beo 6 and Beo4 remotes. LATEST ADDITION: Beogram 7000 with MMC2 stylus....
  • 02-11-2012 12:24 PM In reply to
    • Seanie_230
    • Top 75 Contributor
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    Hi
    For someone who does not know where to look the hdmi connections could be missed. I did not initially find my first time I looked.
    Wha is the type number of your set this will help others to find out exactly what one you have.
    The set has dvi on the earlier model this is input.
    Later models it's the output for Beamer.
    Quick way to check is to go to connections menu and look at av1 and see if you have hdmi in the list.
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
