Latest post 02-23-2012 11:52 AM by f5434964. 5 replies.
Page 1 of 1 (6 items)
  • 02-10-2012 8:03 AM
    Beomaster plays random even though random is turned of
    As topic says, it always plays random. Bm 5 connected to Bv7. No beosound
    Any idea?
  • 02-11-2012 3:14 PM In reply to
    Re: Beomaster plays random even though random is turned of
    Yes. If you start a cd on number/track level it will play the track and then the mots list of the track.
    If you select the cd and not a track then it will play the whole cd from begin to end. You can skip a number if you want.
  • 02-12-2012 1:25 AM In reply to
    1983beo:
    Cant dot this...Remember there is no BeoSound 5 is attached which is where MOTs software is embedded.
    Bring-up your overlay menu and press 3 on your Beo4/5/6.  - Page 8 and 20 in the Beomaster 5 Manual.
    10
  • 02-19-2012 5:25 AM In reply to
    I always thought the BS5 is just a "monitor" and "keyboard"
    does it really contain any software?
    regards Elmar
  • 02-21-2012 11:43 AM In reply to
    Yes it contains the MOTs software/firmware. This either reads the music DNA and stores the data as descrete files in the BM5 or forms part of a two-software code (one in the BS5 ,one in the BM5) which allows the BM5 to do the same.
    Every track has a file and I guess a code/reference which the BM5 "player" element can rank and order for a MOTs playlist.
    If this was not the case, BM5 alone would play MOTs and everyone and his dog would have cloned the saftware onto their music players. This arrangement protects B&O's copy-right.
    Effectively the BS5 is a "Dongle" as well as a monitor and keyboard/mouse)
  • 02-23-2012 11:52 AM In reply to
    Mr10Percent:
    thanks for your answer! Thats a very interesting point!
    Regards Elmar
