Latest post 02-09-2012 1:11 PM by valve1. 2 replies.
Page 1 of 1 (3 items)
  • 02-08-2012 3:15 PM
    • Luke
    • Top 200 Contributor
    • Joined on 02-03-2009
    • Switzerland
    • Posts 286
    BeoLab 5 speaker / tweeter blown
    Just came home today to notice a slight buzzing from one of our BL5s and noticed it was the top speaker. Has anyone else had this ? I tried to do a search on the forum but had no luck.
    Is this part expensive to replace ? I imagine it's mostly the labor cost of the repair ?
    Any help appreciated.
    thanks
    L
  • 02-09-2012 11:21 AM In reply to
    • mjmedlo
    • Top 150 Contributor
    • Joined on 06-07-2008
    • Arkansas, USA
    • Posts 384
    Re: BeoLab 5 speaker / tweeter blown
    The Lab5's are worked on with a 'suitcase'
    I think the dealer/repair shop will order every part needed. .then you get to pay for what is needed.  I had to have an amp module replaced in one of mine.  It malfunctioned above volume level 42.
    The buzzing might be something to do with the amp?  Also, never hurts to try a new chord?
    MJM
    I'm ready for something new that I actually want to buy!
  • 02-09-2012 1:11 PM In reply to
    • valve1
    • Top 500 Contributor
    • Joined on 05-27-2009
    • Dublin Ireland
    • Posts 213
    • Gold Member
    mjmedlo:
    Swap cables (if you can) first before ringing the dealer, also check mains supply to the speaker by wiring it to a socket on a different loop.
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
