Latest post 02-08-2012 5:14 AM by stefan. 26 replies.
Page 2 of 2 (27 items) < Previous 1 2
  • 02-08-2012 2:20 AM In reply to
    • JC
    • Top 100 Contributor
    • Joined on 04-16-2007
    • Yorkshire / UK
    • Posts 621
    Re: Needs help to connect Beosound Ouverture & Beolab 3500.
    Just needs and upgrade by B&O. Can't remember the cost but not crazy money and at least you will have a working speaker!!!!
    Jonnie
  • 02-08-2012 5:14 AM In reply to
    • stefan
    • Top 50 Contributor
    • 200 miles from Struer
    • Posts 1,733
    Can`t believe that you are giving up!
    Took some hours to figure out what the issue is. Now we have it (I think!) and we nearly solve it.....
    Did you really switch your Beolab to ML?
    Press MENU - MENU -(twice) - 0 - 2 - GO (service menu, should be MCL or something like that displayed) - arrow up (to change to ML -
    display shows ML..?) and GO (or STORE) again.
    SW update here in Euroland is about 40-50 Euros for the eprom and maybe half an hour work.
    Good luck.
    Stefan
