Latest post 02-08-2012 5:14 AM by stefan. 26 replies.
Page 1 of 2 (27 items) 1 2 Next >
  • 02-07-2012 7:19 AM
    Needs help to connect Beosound Ouverture & Beolab 3500.
    hello all
    I’m new in this forum, I love B&O appareil, so I’ve buyed some used one (beovision Avant, bs ouverture, beolab 3500 & some beocom ) to try, gradually, to make a nice integrated system.
    Now I have a problem with my BeoLab 3500 & my Ouverture.
    Let's see if I can explain the problem with my bad English.
    I have my Ouverture connected to my BeoLab 3500 with a Masterlink cable and the result is ...disappointing.
    I’m using the beo 4 remote to control “the system” but…I cannot control anything.
    I’ve finished to connect cables and I’ve turn on the system, the clock time appears on the display of BeoLab, but via beo 4 it’s impossible to turn on the music, the overture respond to commands...but not transmit music to the BeoLab.
    Magically, pressing the physical button to the right on the BeoLab  3500 the radio turn on & the music came out from the speaker but…trying to using again beo 4: the overture it’s able to change the music source (radio, cd tape) but does not allow changing the volume, turning off the overture from the remote control the clock reappears on BeoLab.
    I tried different settings (A.opt & L.opt)... but I have not accomplished anything.
    anyone have any suggestions for me?
    Thanks in advance and sorry again for my bad English
    John
  • 02-07-2012 7:31 AM In reply to
    • JC
    • Top 100 Contributor
    • Joined on 04-16-2007
    • Yorkshire / UK
    • Posts 621
    Re: Needs help to connect Beosound Ouverture & Beolab 3500.
    Hi John and welcome to the forum!
      Is the Avant also connected to the set up via ML?
      Are the OT and 3500 in the same room?
    Jonnie
  • 02-07-2012 7:35 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Look for option settings: ouverture option 0, beolab 3500 option 4 (not sure).
    Search the forum for how to set options with your remote.
    Found this thread!
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 02-07-2012 7:37 AM In reply to
    • kallasr
    • Posts 1,077
    Sorry, I assumed only ouverture and bl 3500 are in the room connected.
    Option 0 turns of the ir reciever of the ouverture.
    Option ? turns on the one of the bl 3500....
    Ralf
  • 02-07-2012 7:55 AM In reply to
    The Avant is in the same room whit the ouverture and 3500 but just 3500 & Ouverture are connected via ML.
    Giovanni
  • 02-07-2012 7:58 AM In reply to
    I've tried the setting described in this thread whit no result.
  • 02-07-2012 8:10 AM In reply to
    • stefan
    • Top 50 Contributor
    • 200 miles from Struer
    • Posts 1,733
    Set the whole system to standby.
    If all products are in the same room set:
    Ouverture: A.OPT 0
    Avant: V.OPT 1
    BL3500: L.OPT 5
    The concerning LEDs should flash shorty when you set the options.
    Hope this helps.
    Stefan
  • 02-07-2012 8:28 AM In reply to
    Tried settings described in Stefan post...not work  LEDs flashed shorty in Avant & ouverture but not in beolab.
    ...!no result|
    I have to go to the dealer b&o?
    p.s.: No dealer in my city! just 1 in all my region.
  • 02-07-2012 8:48 AM In reply to
    • hfat
    • Top 500 Contributor
    • Joined on 05-18-2010
    • Austria
    • Posts 176
    • Gold Member
    Hello,
    If I understood your installation correctly:
    Avant and Ouverture in one room and NOT connected by Masterlink
    BL 3500 in another room ML connected to Overture
    The Option setting should be:
    Avant: V_OPT 1
    Ouverture: A_OPT 1
    BL 3500: L_OPT 5 or 6
    Do You have speakers connected to your Ouverture. If not, it could be that the Ouverture defaults to A_Opt 0
    In this case you should to ML it to the Avant:
    Avant: V_Opt: 2
    Ouverture: A_Opt: 0
    BL 3500: L_Opt 6
    hfat
  • 02-07-2012 8:58 AM In reply to
    Hi, before trying link settings etc, did you make the masterlink cable yourself? If so it's very easy for one of the cables to not make a clean connection causing all kinds of issues.
    Can you try a different masterlink cable? This will ensure that the connection between the two units is not at fault.
    Regards,
    Cal
  • 02-07-2012 9:25 AM In reply to
    • stefan
    • Posts 1,733
    hfat:
    Hello,
    Avant: V_OPT 1
    Ouverture: A_OPT 1
    Avant: V_Opt: 2
    Ouverture: A_Opt: 0
    BL 3500: L_Opt 6
    hfat
    pinkogio:
    Giovanni
    Stefan
  • 02-07-2012 9:31 AM In reply to
    • stefan
    • Posts 1,733
    Did you use LINK OPTION for your BL3500?
    Must be L.OPT 5.
    If this doesnot work disconnect the BL3500 fromm the mains for 2 minutes, reconnect and try again.
    If this doesn´t work disconnect Masterlink from BL3500 and try L.OPT setting once more.
    If this doesn`t work, check ML cable as Cal already said.
    Stefan
  • 02-07-2012 10:29 AM In reply to
    All products are in the same room set: Avant and Ouverture NOT connected by Masterlink. BL 3500 ML connected to Overture, NO speakers connected to Ouverture.
    Ouverture: A.OPT 0
    Avant: V.OPT 1
    BL3500: L.OPT 5
    I've tried to use LINK OPTION for BL3500 but seems not working even I've tried the procedure recommended by Stefan (connect & disconnect etc.)
    Tried to check cable, I've buyed & not make the masterlink cable from myself...they work perfectly connecting ouverture to Avant.
    evrithing seems to be perfect but...not work!
    bah!
    Mysteries of the high tech up to date or slightly exceeded!
  • 02-07-2012 10:42 AM In reply to
    • stefan
    • Posts 1,733
    How old is your Beolab? Did you buy it second life? Maybe its an LCS9000 and not a BL3500. Could be set to MCL...(?) So it won`t respond to ML.
    http://forum.beoworld.org/forums/p/5421/39403.aspx#39403
    Stefan
  • 02-07-2012 10:48 AM In reply to
    • stefan
    • Posts 1,733
    Thanks to Keith:
    "Extract from my FAQ on the subject
    When I purchased my LCS9000, I was told it could only be used with MCL (Master Control Link), is this true ?
    No, All units from day one shipment had both MCL and Master Link, however on the LCS9000’s the masterlink socket was covered with a black plug which made it appear that it only had MCL.
    To use the MasterLink you need to remove the black plug and enable it via a service menu command. To get into the service menu to switch between ML & MCL press MENU then MENU then 0 then 2 then PLAY, then use the up arrow to switch, then store"
    http://forum.beoworld.org/forums/p/5805/42552.aspx#42552
    Stefan
  • 02-07-2012 10:51 AM In reply to
    LCS9000 or BL3500 this is the problem! (Maybe:)
    where do I recognize the model
    p.s. thanks for all the attempts to solve the problem
  • 02-07-2012 10:54 AM In reply to
    • JC
    • Yorkshire / UK
    • Posts 621
    It will be on the small label where connections are made!
    Jonnie
  • 02-07-2012 10:57 AM In reply to
    MCMXCIII (1993)
    S. 1.1
    • stefan
    • Posts 1,733
    pinkogio:
    Just...
    "press MENU then MENU then 0 then 2 then PLAY, then use the up arrow to switch, then store"
    You will see (hear) what happens...
    Stefan
  • 02-07-2012 11:00 AM In reply to
    • stefan
    • Posts 1,733
    SW 1.1.. I think you have to update..Must be the old LCS9000 with MCL.
    My BL3500 just got SW3.3
    Stefan
  • 02-07-2012 11:06 AM In reply to
    with my beo4?
  • 02-07-2012 11:32 AM In reply to
    Bellissimo! Now I have a beautiful aluminum tube but...with a great WOW EFFECT B&O STYLE!
  • 02-07-2012 1:42 PM In reply to
    ...decided to use it as a desk clock!
  • 02-07-2012 1:51 PM In reply to
    • stefan
    • Posts 1,733
    Doesn`t work?
    Stefan
  • 02-07-2012 5:13 PM In reply to
    Unfortunately does not work.
    This is my new clock: beolab 3500!
    Anyway, thanks for all the advice.
    Giovanni
