Latest post 02-07-2012 1:50 AM by yachadm. 6 replies.
Page 1 of 1 (7 items)
  • 02-06-2012 12:08 PM
    • Jeff
    • Not Ranked
    • Joined on 03-01-2010
    • USA
    • Posts 48
    • Gold Member
    Phono Preamp Option
    This may be discussed elsewhere, but couldn't find it, so I'm posting this anyway. Stick out tongue
    I have a Beogram 3300, the wedge shaped turntable, connected to a Beosound 9000. There was always enough level difference it was annoying, plus having to use an old integrated amp for its phono preamp. Anyway, I got one of these:
    http://www.phonopreamps.com/TC-770LCpp.html
    This unit has a DIN connector on the back, so that you don't have to use an adaptor to go to RCA and ground wire. It also has a variable gain, I was easily able to up the gain on the table so it matched the Beosound CD and radio with just a touch of gain.
    So far I'm very happy with the sound, and the fact the levels are matched. I can recommend this as a good phono preamp for B&O tables. When I contacted the dealer, he directed me towards this when he heard I had a Beogram, for the reasons mentioned, DIN connector and the low gain of the B&O cartridges.
    Good product, seems solidly made, and solves a number of problems.
    Filed under:
  • 02-06-2012 2:45 PM In reply to
    Re: Phono Preamp Option
    I have been using a TC750LC from the same company for 2 or 3 years now and have been more than happy with it.
    All their business is done over the net .
    I can recommend the company and its products.
    Regards Graham
  • 02-06-2012 3:27 PM In reply to
    joeyboygolf:
    Ditto!
    Nice piece -nice price.
    Recommended! Yes -  thumbs up
    • B&o bottle opener
  • 02-06-2012 4:34 PM In reply to
    That RIAA sure looks interesting, could use a couple in my system Smile
    Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
  • 02-06-2012 7:45 PM In reply to
    Thank you for the link. Guess i'll buy one of these...Yes -  thumbs up
  • 02-07-2012 12:46 AM In reply to
    I've been using the 750 for 5 years now, no problems what so ever, and shipping and handling from the company is first class.
    Some audiophiles tested this preamp and gave it good critics, compareable with preamps in the 4/500 USD class.
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 02-07-2012 1:50 AM In reply to
    • yachadm
    • Top 100 Contributor
    • Joined on 06-24-2007
    • Jerusalem, Israel
    • Posts 687
    Here is a Danish company making drop-in replacements for the original RIAA amplifier (and better components now), and of course it can be used to put an RIAA amp in those turntables which never had one before.
    http://www.mb-el.net/side3.html
    Menahem
    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
