Latest post 02-09-2012 5:49 PM by Søren Mexico. 15 replies.
Page 1 of 1 (16 items)
  • 02-06-2012 3:22 AM
    • classic
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Venø - Struer / Denmark
    • Posts 224
    Beovox 5000 - Upgrade
    I have started to upgrade my Beovox 5000 MKIII designed for Beolab 5000 (1967-1972).
    I am planning the following:
    Replace the capacitors in the crossover network
    Replace the internal wiring to the bass driver
    Replace the external cable
    Coat the cones of the midtone- and bass drivers
    /Frede
    Beolab 5000 -  "If another amplifier sounds different then it needs repair!"
  • 02-06-2012 3:29 AM In reply to
    • classic
    • Posts 224
    Re: Beovox 5000 - Upgrade
    Bipolar capacitors produced for more than 50 years ago are dried out and need replacement.
    I will replace the capacitors with some (expensive) MKT film capacitors (metallised polyester film)
    I am using some from Bennic and Monacor
    Here you can see the old bipolar caps and the new film capacitors.
    /Frede
  • 02-06-2012 3:31 AM In reply to
    • classic
    • Posts 224
    I am going to start the process by replacing these capacitors.
    You need to remove the bass speaker and some damping material.
    Then you can see the crossover filter.
    You can then remove the 4 bolts and careful remove the filter for a more easy restoration.
  • 02-06-2012 3:34 AM In reply to
    • classic
    • Posts 224
    I don’t remove any wires at this stage.
    I only pace the filter at the top of the cabinet and do the work here. I suggest using some protection between the filter and your Beovox 5000.
    The process require a few changes to the filter because the new caps are physical much bigger and more heavy.
    I will rearrange and I will use hot melt gluing of the caps.
    This is the result of the rearranged part for the crossover filter.
    The reason for gluing the parts is of course avoiding noise and vibrations.
    more to come Smile
  • 02-06-2012 9:02 AM In reply to
    Fascinating - I should really do mine sometime! I am not convinced that the bass units in mine are original though - smaller dust caps.
  • 02-06-2012 9:36 AM In reply to
    • classic
    • Posts 224
    I think yours are original Peter, the MKIII have been sold with 2 types of bass units - one with 'big dust cap' and one with small dust cap'
    /Frede
  • 02-06-2012 1:56 PM In reply to
    You may well find there is a significant advantage in replacing the wirewound resistors, modern ones are much more accurrate.
    If you measure the values of these resistors, you may well get a shock, mine had drifted massively, you might imagine that a drift of a few Ohm isn't much, but when you are dealing with the low values found in crossover netowrks, that dirft can be over 100%.
    How do I know, because I did this same exact thing a few years back.
    Make sure to refix those chokes too, the glue will be on the way out.
  • 02-06-2012 1:57 PM In reply to
    Don't forget to check out the components on the crossover frequency adjustment controls too.
  • 02-06-2012 2:23 PM In reply to
    • classic
    • Posts 224
    Casdave,
    First, thanks for your suggestions, I will certenly check - and remplacer if needed.
    This is really interesting.
    What was the final result of your restoration ?
    /Frede
  • 02-06-2012 3:39 PM In reply to
    The sound was pretty dull and lifeless, and this did improve things, however the addition of the cubes made all the differance in the world.Bass seems to go a bit deeper and less boomy.
    It was not a massive improvement, but noticeable. Add up all these little improvements and it can make a big difference.
    I also did a pair of Type Ks, the cones were gone at te edges, not an easy repair due to them being corrugated paper types. Now sorting these and the crossovers made a huge difference.The bass response is so much better. I would even argue that they sound nicer than the Beovox 5000.
    The type S only needed the capacitors doing, but while you have the speakers apart, it is a good time to refinish the wood too. You'd be amaazed at just how grotty the cloth grilles have become.
  • 02-07-2012 1:24 AM In reply to
    classic:
    more to come Smile
    Sure looks crowded, I dont see the 3rd coil, is it hidden under the 68 Mu cap, and did you glue the cap to the coil ??
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 02-07-2012 1:51 AM In reply to
    • classic
    • Posts 224
    Søren Mexico:
    Yes, the 68uF cap is glued on top of the coil and to the other 68uF cap.
    /Frede
  • 02-07-2012 12:15 PM In reply to
    classic:
    If you had to take it out again, wouldn't the glue damage the coil ??
    By the way I use transparent silicone for gluing, it takes longer time to set, but is easier to clean of and more flexible when dry, the glue from the heatgun gets very hard.
  • 02-08-2012 1:25 AM In reply to
    • classic
    • Posts 224
    Søren Mexico:
    Please have a look at the photo of the filter "before" upgrade (2.nd. photo on this thread) - you will see the the "pertinax" washer on top of the coil.
    /Frede
  • 02-09-2012 4:20 PM In reply to
    • Rich
    • Top 50 Contributor
    • Joined on 07-10-2010
    • Orlando, Florida, USA
    • Posts 1,089
    • Gold Member
    classic:
    more to come Smile
    Everything I've read over at diyaudio.com would lead me to believe those two inductors (coils/chokes) are too close together and should be separated to prevent magnetic field interferences.
    Current primary listening:  SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
  • 02-09-2012 5:49 PM In reply to
    Rich:
    Here is my 3702 original filter, induktors allso close together.
