Hello Erik-NL
Today evening I can check my values and respond them to you
hfat
If you have an official BV4, which I assume. Then some of the values are noted on the back of the BV4.
These (calibrated) values have to be set in this BS2 menu.
Oh, I remember things again.
Inside the BS2 there is an aluminium labelled box. (tuner).
On that label, some info has been written.
Look:
in case it helps, my values:
rdr 36
gdr 35
bdr 37
bri 36
con 25
wpr 19
wpb 20
rct 29
bct 46
briof 16
conof 39
colof 16
color temp norm
comb filter on
movie mode on
gain adjust 120 124 +23 +9 -13 on
