Latest post 02-04-2012 9:47 AM by Alex. 3 replies.
Page 1 of 1 (4 items)
  • 02-04-2012 7:38 AM
    help!!
    Hi
    I can't manage to listen tv audio in the audio system speaker
    My Beovision 6-26 is connected, through Beolink converter 1611, to Beomaster 6500 (Tv-Aux exit)
    what I have to do with Beo4 to make it work?
    The istruction are not esay to be understood...
    Anyone can help me?
    Thanks so much
    Gianluca
  • 02-04-2012 9:33 AM In reply to
    • Daniel
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Svinarp, Sweden
    • Posts 1,284
    Re: help!!
    Do you have them in the same room?
  • 02-04-2012 9:43 AM In reply to
    • stefan
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: help!!
    Try to set the options correctly first.
    If both systems are in the same room, and speakers connected to BM6500, set audio option to 2:
    Press SOUND - 2 - STORE
    Set video option to 0:
    Press PICTURE - 0 - STORE
    Standby LED should flash for confirmation.
    If both systems are in diferent rooms set A.OPT to 2 and V.OPT to 2.
    If you have a BEo4 consult the manual for option settings.
    Now it should be possible to listen to TV sound via your BM6500 by selecting source (TV, DTV, V.AUX....).
    Stefan
  • 02-04-2012 9:47 AM In reply to
    • Alex
    • Top 500 Contributor
    • New York, NY
    • Posts 176
    Re: help!!
    amagian:
    Hi
    Anyone can help me?
    Thanks so much
    Gianluca
    Is the TV audio source you're trying to listen to connected over HDMI?  You might have a problem with that particular TV if you're not using the analog connections.
    Store Manager Bang & Olufsen Broadway 927 Broadway New York, NY 10010
