Latest post 02-01-2012 3:25 PM by moxxey. 5 replies.
Page 1 of 1 (6 items)
  • 02-01-2012 5:34 AM
    • steph
    • Top 100 Contributor
    • Joined on 04-16-2007
    • France
    • Posts 612
    BeoLab 12 with floor stand ?
    BeoLab 12 is an on-wall loudspeaker.
    But, maybe B&O could bring a floor stand for this speaker or a new BeoLab 12-2 model ?
    I remember Roger was talking about two BL 12 models and saw a picture of the BL12 on floor stand on a spanish dealer website.
    I think the BL12 on a floor stand could perfectly match my floor stand BeoVision 10-40 ! Yes -  thumbs up
    Do we know any informations about this ?
  • 02-01-2012 7:39 AM In reply to
    Re: BeoLab 12 with floor stand ?
    It can never be a floorstanding loudspeaker as it needs a wall behind it to create bass from the rear mounted speakers, so wall mounted will be the only way to have them. They do look great though, especially with the 10-40 as they are the same height.
    BV7-40MK4BR,7-32,6-22,6-23,6-26,BSnd5,9000,BLab9,3,4000,2,BCom2,6000,Btalk1200,LC2s,Lutron
  • 02-01-2012 8:17 AM In reply to
    • steph
    • France
    • Posts 612
    Yes Martin, it's true !
    Thanks for the answer.
    So, maybe a small on-wall BL12 to match the wall-mounted BV10-32...
    What a pity !
  • 02-01-2012 10:27 AM In reply to
    • Beofan2
    • Top 200 Contributor
    • Joined on 07-31-2007
    • Fredericia, Denmark
    • Posts 313
    Steph the 12-2 is a small version. About 50 cm tall. Price tag is 12 500 DKK
    It´s not magic - it´s Bang & Olufsen
  • 02-01-2012 10:52 AM In reply to
    • steph
    • France
    • Posts 612
    Thanks for the info ! Wink
  • 02-01-2012 3:25 PM In reply to
    • moxxey
    • Top 25 Contributor
    • Joined on 04-14-2007
    • South West, UK
    • Posts 2,360
    MartinW:
    It can never be a floorstanding loudspeaker as it needs a wall behind it to create bass from the rear mounted speakers...
    My dealer told me there WILL be a floorstanding version of the BL12s as B&O want it to compliment the BV10. He said it will follow, but I forgot ask how they'd handle the bass issue. Perhaps it might be floorstanding, but has to be close to a wall? :)
    If not, and he was wrong, I'll get some BL3s instead.
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
