Hi All,
Just bought 2nd hand Beo4 with the following upper part key pad :
TV/MENU/RADIO
DVD/CINEMA/CD
MyVideo/MyPC/MyMusic
Wanted to use it in my den, where I'm using a BV6 as a PC monitor AND as a TV (via a decoder).
The My PC key is perfect, I have an instant access to my PC (which makes sense.....)
I would like to watch TV pressing the My Video key, but I don't know if I can program that key with another function than CAMCORD...which appears on the BV6 when I press it.
If ever somebody knows.... Thank you in advance!
Regards from snowy French Alps,
Laurent.
Avant 28 DVD, BC2, 2300, BL2500, 8000, to name a few...
